speed issues
- Feedback
- Plusnet Feedback
- speed issues
Re: speed issues
01-12-2009 3:47 PM
A post you may find informative: http://community.plus.net/forum/index.php/topic,74056.msg590818.html#msg590818
Re: speed issues
01-12-2009 4:43 PM
Quote from: stormrunner hi
caccy i know its getting realy silly, have u checked ur download speeds after midnite, at the moment mine are what they used to be during the day, have a look and see..
69gillan have u checked ur line speed with the bt speed checker, it will let u know what ur line can handle, pierre_pierre posted a link to it a couple of posts ago.
well im still getting the [email protected] speed and if plusnet dont get it sorted out within the next few days im outa here...
Your shift key is mostly broken.
Re: speed issues
01-12-2009 5:41 PM
cant think why
jelv thanks for pointing out that post would be nice to see a plusnet reply to it, so the question is :is plusnet unlimited realy unlimited or is the product being missold?
[Moderator's note by Jim (Oldjim) avoidance of the swear filter is against [Forum Rules] ]
Re: speed issues
01-12-2009 6:23 PM
To all of you (including stormrunner), then please do the following -
1) run a BTspeedtest and post the full results, not just edited highlights, do a text copy and paste (no need for jpegs etc, see below
2) Login to the member centre https://portal.plus.net/my.html?action=data_transfer_speed and post info (text copy & paste again) delete last 4 digits of phone number if displayed
3) Run the PN speedtester http://www.mybroadbandspeed.co.uk/ and post results
4) Check which gateway you are on - http://usertools.plus.net/@gateway/ and post info
BT speedtest
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
610 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 610 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :6912 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
Edit: @stonesfan - just found your thread on the Speed board - will post there.
Re: speed issues
01-12-2009 7:27 PM
Quote from: stormrunner so the question is :is plusnet unlimited realy unlimited or is the product being missold?
By unlimited Plusnet mean that there are no penalties (financial or otherwise) that kick in as your usage rises. However Plusnet have to buy centrals and cater for the peak usage of all their customers. If it was really unlimited with no throttling of protocols I'm guessing the account would cost well in excess of £50 per month. Obviously that's not a goer, so Plusnet throttle the speeds to various degrees during the day so that they can keep the total usage down and hence offer the product at a competitive price. As I posted, the product is unmetered, but it is far, far from unlimited.
Re: speed issues
01-12-2009 7:37 PM
heres my latest speed info
From plusnet:
Telephone number:
01495******
Phone exchange:
TREDEGAR
Estimated line speed:
7 - Checked on 2009-11-28 19:40:05
Current line speed:
6500
From Bt test:
Download speedachieved during the test was - 5630 Kbps
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
as i said before i have great speed after midnight but during the day it drops to around 120kbs and below 30kbs at peek times, this has been going on for almost 3 weeks now.
Re: speed issues
01-12-2009 7:39 PM
You may find you get better speeds by trying a different gateway.
Re: speed issues
01-12-2009 7:54 PM
plusnet cant/wont/ havent been able to tell me why.
is it worth trying another gateway, and if so then why havent plusnet support suggested it?
Re: speed issues
01-12-2009 8:38 PM
Whenever the network is out of balance a gateway hop or two is always worth trying.
What hasn't helped is the number of problems being thrown up when people are moved over to 21CN due to failings on the BT side which has perhaps meant that they have been stretched dealing with issues and also that they haven't been able to take advantage of the cheaper 21CN network to provide more capacity for the same package prices to the extent they had planned.
Re: speed issues
01-12-2009 9:24 PM
Re: speed issues
01-12-2009 9:52 PM
as you said you were getting slightly faster speeds before, you need to sync at maximum speed. I'm still a bit concerned to check that there isn't any issues with your connection affecting this. Could you post your modem/router ADSL line stats, that's Downstream (DS) & Upstream (US) Sync/Connection speed, Attenuation, Noise Margin (SNRM) & Power. Check here - http://www.kitz.co.uk/adsl/frogstats.php if you need help to get them.
Re: speed issues
01-12-2009 10:25 PM
Link Information
Uptime: 4 days, 8:11:00
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 13.5
Line Attenuation (Up/Down) [dB]: 7.0 / 9.0
SN Margin (Up/Down) [dB]: 22.0 / 10.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 253
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
DSL Connection
View more...
Uptime: 4 days, 8:13:15
Re: speed issues
02-12-2009 12:33 AM
As you are so close to the exchange, I doubt you'd have any problems with errors if you had Interleaving turned off - that's off - not auto. You'd then sync at 8128 with a profile of 7150 (the maximum).
Re: speed issues
02-12-2009 1:02 AM
thanks for that, im going to pretend that i understood what all that ment
is there a book on the subjecthopefully with popup pictures...
Re: speed issues
02-12-2009 1:16 AM
Interleaving also increases the ping or lag time, so if you are a gamer, you ideally want Interleaving turned off to get the quickest responses. (Interleaving has 3 settings On, Auto, Off). With Interleaving off, you will also connect to the exchange at the fastest possible speed because you are sufficiently close, this will give you the fastest throughput of data.
