slow replies on tickets
- Feedback
- Plusnet Feedback
- Re: slow replies on tickets
26-02-2010 5:27 PM
all im after is my IP Profile line lifting to 2000
after moving my router to differant sockets the ****** max stable rate has kicked in
my question to PN was why does my next door neighbour on the the same pole ... same exchange on but onTiscali
not get hit by max stable rate no matter how many times he re-boots or turns off ?
and he gets better download speeds upto 2300
we are on identical routers .... plugged into master sockets and my BT test results say my line will support 2000kbps
Download speedachieved during the test was - 1302 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2016 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
26-02-2010 6:42 PM
How many times did you change sockets..... and how much time expired betweeen each move?
26-02-2010 6:59 PM
but want to know if max stable rate is a PN thing or at the BT exchange and why it does not effect nextdoor on tiscali
26-02-2010 7:09 PM
26-02-2010 7:49 PM
just done a Bt Speed test
Quote The Performance Tester is now testing Broadband connection. Your configured download throughput speed for this service is 1500 k
and the result is...............
Quote Download Speed
1311 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1311 Kbps
So I think there is little more you can do.....
I am on the end of a 63.5db Download Attenuation, and since 08:00 this morning have had aDownload SNR of between 5.6db and currently ... 3.8 db which is about the same as yesterday....
Further information, I am on a wireless connection to my laptop.... the router is on the end of a 15 mtr hardwired extension with three phone sockets between me (the router) and the master socket. !
26-02-2010 8:02 PM
max stable rate is doing my head in
all double dutch to me
Line Attenuation 61 db 15.5 db
Noise Margin 6 db 17 db
26-02-2010 8:06 PM
27-02-2010 12:38 AM
27-02-2010 11:23 AM
Connection Speed 2304 kbps 448 kbps
Line Attenuation 60 db 15.5 db
Noise Margin 8 db 17 db
speed tested download at 1.99mb
mine this morning is
Connection Speed 1440 kbps 448 kbps
Noise Margin 9 db 18 db
speed tested at 1.15mb
like i said .... same exchange .... same telegraph pole ..... same router
mine is plugged into the master socket
the only differance is isp
any ideas ?
27-02-2010 11:27 AM
27-02-2010 2:56 PM
For a sync speed of 1440kbps the appropriate IP Profile is 1250kbps (which you have) and your measured download speed is consistent with that.
27-02-2010 3:03 PM
its currently in the front of the socket ......... i would try the test socket but if do that now max stable will kick me down even more wont it
27-02-2010 5:10 PM
28-02-2010 3:15 PM
can i have my line ip profile reset please PN
28-02-2010 7:55 PM
