phone moved over to pn
goatty2
I have been with PN for about 6 months on 40/10
BT line contract was up so moved  the phone over to PN and was a bit apprehensive as had a problem when setting the the fibre.
no need to worry  though as everything went very smoothly, kept the same number and caller display.
well done.
5 REPLIES 5
adamwalker
Fixes: 221
Re: phone moved over to pn
Glad to hear everything went to plan. Just let us know if you come across any issues.
 Adam Walker
goatty2
Hi Adam
just looked at the call features
green square next to caller display which i asked for
green square next to voicemail which i did not ask for but says it free, is this right?
newagetraveller
Voicemail is free and active by default. I prefer my own answering machine so have it turned off. It's BT's 1571 service I think.
adamwalker
Fixes: 221
Hi, as newagetraveller says it is free, give me a shout if you need that removing.
 Adam Walker
goatty2
thanks newagetraveller and adam
thought you had to pay for it as bt charge for it
if its free i'll keep it
