checking past usage
lel
checking past usage
Why can't you get a detailed check of past usage, I had usage showing even though I was not in the country. Any help
3 REPLIES 3
AlaricAdair
Champion
Re: checking past usage
If it was last Thursdayoff peak, it may be down to maintenance by PN. Apparently no charge for that bandwidth.
Now Zen, but a +Net residue.
lel
it was in July's usage and apparently no one can check past usage, seems rubbish to me.
Chris
Legend
Fixes: 169
We can tell you how much data you used per hour normally, but we can't break it down further than that historically.
