Will it get better?
- Feedback
- Plusnet Feedback
- Re: Will it get better?
- « Previous
- 1
- 2
- Next »
05-01-2012 8:57 PM
in general if the synch is below 4000 its not worth trying ADSL2, Jo Jo can he go onto ADSL (992.1) as a trial, it might give them a higher speed
15-01-2012 2:36 PM
I signed up with plus net after moving home recently, when i carried out the "estimated line speed test" prior to signing up i was estimated to get a 7mb +/- 1mb connection which sounded great, if not a bit generous
Phone exchange:
AMBLE
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-11-25 13:10:04
Current line speed:
0.25 Mb
I have raised a ticket and had a BT engineer out to see if there were any problems. He told me that i would never in a million years get 7mb (which i knew from the off) but said i should get a stable 1mb connection at the time my line speed was averaging 0.4mb and he told me that the line was running at only 50% of its capacity? Since his visit about a month ago my speed has decreased to the current 0.25mb. I have attached a speedtest.net url that i carried out today.
So my question is... Does it really get better? Or should i consider getting one of those mobile broadband dongles and just give up with wired broadband.
15-01-2012 2:49 PM
... but the service has remained fairly stable.
The only thing I can add at the moment is that the service is noticeably slower during the evenings.
15-01-2012 8:41 PM
That estimated speed result seems suspicious given the circumstances you describe. Had your phone number recently been assigned to a different line?
What estimate is given now if you put your number into the BT Wholesale Broadband Availability Checker?
Posting your router stats - from here if you are using a Thomson router, or see Kitz frogstats - would help Community members give more informed comment.
David
15-01-2012 8:52 PM
"Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 3.5Mbps; typically the line speed would range between 2Mbps and 6Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 5.5Mbps; typically the line speed would range between 4.5Mbps and 9Mbps."
So my quesion is, why am I not getting an ADSL2+ connection from Plusnet?
15-01-2012 9:24 PM
Quote from: gstrickland So my question is, why am I not getting an ADSL2+ connection from Plusnet?
The MSAN at the exchange has determined the higher ADSL2+ frequencies contribute nothing - so it uses ADSL2 for your connection.
Does your distance by road from the exchange given by Kitz's availability checker tie in with that implied by your attenuation (3.9km)?
David
15-01-2012 10:06 PM
(appx)* By Road: 3.06 km
Link Information
Uptime: 6 days, 7:07:19
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 960 / 2,572
Bandwidth (Up/Down) [kbps/kbps]: 444 / 3,160
Data Transferred (Sent/Received) [MB/GB]: 361.28 / 4.28
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 31.0 / 53.5
SN Margin (Up/Down) [dB]: 20.5 / 3.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 96 / 0
FEC Errors (Up/Down): 0 / 46,973,135
CRC Errors (Up/Down): 163 / 6,523
HEC Errors (Up/Down): 112 / 37,408
15-01-2012 11:25 PM
David
16-01-2012 12:34 AM
16-01-2012 1:07 AM
David
16-01-2012 9:23 AM
Quote from: spraxyt @IanR273
David
Thanks for the reply my router is a belkin n1 and i think these are the stats your asking for...
Status
Version Info
Firmware Version
F5D8632-4_WW_1.00.06
Boot Version
v1.01
Hardware
F5D8632-4 v1
Serial No.
20913863200164
LAN Settings
LAN/WLAN MAC
00:1C:DF:A2:70:5C
IP address
192.168.2.1
Subnet mask
255.255.255.0
DHCP Server
Enabled
Internet Settings
WAN MAC address
00:26:BB:12:C1:0F
Connection Type
PPPoA
Subnet mask
255.255.255.255
Wan IP
46.208.184.110
Default gateway
195.166.130.73
DNS Address
212.159.6.10 212.159.6.9
Features
Firewall Settings
Enabled
SSID
Belkin_N1_A2705C
Security
Enabled
WPS
Enabled
Guest Access
Disabled
ADSL
Status
UP
Downstream Upstream
Data rate(Kbps)
320 416
The BT wholesale url quotes a broadband line speed of 1mb ranging from 250kbps to 2mb.
On the plus side according to the BT wholesale link the exchange i am currently on is due to be upgraded to adsl2+ in march, and i should get a line speed of between 1mb and 3.5mb so hopefully i may get a speed boost soon. But it looks like i am stuck with dial up speeds till then
Just a shame i am expected to pay the same as people in areas with up to 8x the speed i have, hardly seems fair in my opinion.
16-01-2012 9:47 AM
17-01-2012 12:19 AM
Quote from: IanR273 ADSL
Status
UP
Downstream Upstream
Data rate(Kbps)
320 416
That information provides your downstream and upstream sync speeds, and the IP Profile for 320kbps sync speed is 250kbps - the value shown in the Member Centre as Current line speed.
Since you had a higher sync speed initially I wonder if the DLM has increased your target noise margin to reduce disconnections and/or transmission errors - was the connection previously prone to dropping?
Does the router status page that contains the sync speed information include any Operating Data, in particular Noise Margin, Attenuation, CRC Errors and HEC Errors?
Regarding the potential for slightly increased speeds on 21CN/ADSL2; those estimates might reflect the small green shaded area above 70dB attenuation on the Internode graph on this page. Sorry to sound pessimistic but I doubt there are many willing to bank on that being a real effect.
David
- « Previous
- 1
- 2
- Next »
