View my Usage - Has it stopped working?
- Feedback
- Plusnet Feedback
- Re: View my Usage - Has it stopped working?
08-06-2014 12:02 PM
If however the recorded usage you can see is more than 10GB
08-06-2014 12:35 PM
Ex-Plusnet Jobsbody
08-06-2014 12:40 PM
That is NOT what you just said in reply to my post.
If you've recorded >10GB or if you have recorded and displayed > 10GB?
The issue here is about customers who are unable to manage their own usage because PN is unable make the correct information available to them,
If you are going to charge for going over the limit if the customer is unable to see that they are in danger of doing so because of a fault with PN's systems, that is entirely unreasonable and unacceptable.
08-06-2014 12:44 PM
We don't want to be charging you for usage you couldn't have controlled.
Ex-Plusnet Jobsbody
08-06-2014 12:49 PM
To be very clear
If the recorded usage which can be seen by the customer exceeds the limit then they will be charged
If the recorded usage which can be seen by the customer doesn't exceed the limit then they won't be
Edit - I didn't see Kelly's last post before writing this
08-06-2014 1:11 PM
PN are "looking at" putting a note on the VMBU page to advise, but apparently their change systems are so complex it will probably be fixed before they get round to it (I'd have a word with whoever designed the change systems, because they clearly have a grossly inflated overhead even for simple tasks)
BUT ... PN already have a perfectly serviceable protocol for communicating problems - Service Status Notices; but this problem is not appearing in the SS page either ...
sigh
09-06-2014 12:17 PM
09-06-2014 3:54 PM
Quote from: Chris Service Status now up:
Sorry to disappoint you but mine is still showing 0KB. So, it seems it is NOT up for everyone.
Many regards.
09-06-2014 4:19 PM
09-06-2014 4:23 PM
09-06-2014 4:49 PM
09-06-2014 4:54 PM
Quote from: Chris That's what the Service Status explains.
Sorry, Chris. My sincere apologies. In a hurry, I misread your post.I had quoted.
Sorry again.
Many regards.
10-06-2014 3:42 PM
10-06-2014 4:36 PM
10-06-2014 4:58 PM
- Feedback
- Plusnet Feedback
