Usage statistics
DougForum
Usage statistics
I would like to see the usage statistics available for a longer period. If you are unable, or forget to record the figure daily you can miss a day or too at the change over month end.
I'd also be intereset in the ability to download a .csv file of the stats for my own records.
If you require further clarification please ask.
Many thanks
1 REPLY 1
Chris
Legend
Fixes: 169
Re: Usage statistics
Thanks for the suggestion. I hope you don't my being blunt, but as the vast majority of our packages are Unlimited, it's unlikely we'll be adding in additional features on to View My Usage.
If you do need information about a specific day, just let us know and we can usually get that for you.
