Unacceptable connection speeds
- Feedback
- Plusnet Feedback
- Unacceptable connection speeds
Re: Unacceptable connection speeds
06-01-2010 12:11 PM
Thanks for the help.
06-01-2010 12:40 PM
Has he connected up your extension sockets as well? If he has is the router now plugged in to the new master socket or one of the extensions?
Can you post the stats shown by your router (sync speed, attenuation and noise margin) please. It's going to take a few days for BT's systems to recognise your improved line and we'll be able to predict what sort of speeds you should see. We'll also make sure you get the best possible out of your line.
06-01-2010 1:22 PM
I will post back.
06-01-2010 1:54 PM
If you can post the router stats from where you normally have the router and then when it is plugged in to the test socket we will be able to tell how good the internal wiring is (I guess it doesn't look like he touched that).
06-01-2010 2:04 PM
06-01-2010 2:11 PM
06-01-2010 2:19 PM
06-01-2010 2:21 PM
06-01-2010 2:21 PM
i think you are speed limited to 7616 because interleaving is switched on
06-01-2010 2:23 PM
With regards to interleaving, should I switch this off?
06-01-2010 2:28 PM
Guess I should leave it on.
06-01-2010 2:29 PM
06-01-2010 2:36 PM
Just to confirm though, would putting the router downstairs not make a difference? I suppose I need to see how I get on with the connection for a day or two?
06-01-2010 2:38 PM
06-01-2010 2:42 PM
