Unacceptable connection speeds
leewilson78
Re: Unacceptable connection speeds
It is on channel 13, I seem remember changing it from 12 to 13 some time ago. I changed it to 1 prior to posting here, but the connection went all together.
Fixes: 1,495
I would try 12, I have found 1 & 13 temperamental with some kit myself.
leewilson78
Ok, I've assessed the connection the last couple of days, no improvement since BT came out and fixed the line. What do I do next?
Oldjim
Resting Legend
Fixes: 63
In what way is there no improvement
I haven't seen any speeds from your router since post 45
jelv
Fixes: 10
Can you explain "no improvement" please. At the moment you should be looking for a stable sync sped at the higher level with no loss of sync. As I said in reply #65 it can take some days for the IP Profile to increase and therefore before you see faster speed test results.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
leewilson78
@jelv, no problem, I'll leave it til Monday. I think the problem was never connection speed, it was more that it frequently dropped.
jelv
Fixes: 10
Have you had any drops or does the router now show 2 days+ up time?
leewilson78
Where do I find this information, on 192.168.2.1 ?
leewilson78
I have noticed that there is a Globe icon on my router, this is flashing green then off, should this be solid green?
leewilson78
Tried everything now, hopefully PN will realise that is could actually be something there end!
jelv
Fixes: 10
Lee - you still haven't given it enough time since your line was fixed!
leewilson78
I am confident that it will  make no difference, I don't think it is related  to the line. Test carried out by PN show that the connection is consistently dropping, I can't understand why leaving it for a few days will make any difference.
Just out of interest, how long will PN expect to leave it?
I have submitted numerous, support tickets, I've been passed from pillar to post. I initially got scaremongered into not doing anything, the threat of being charged £144 if someone from BT came out and found out it was my problem. That made me delay for a good couple of months. Then I get it fixed and nothing has improved,  I'll just sit on my hands for a couple of weeks I guess.
leewilson78
The only thing I haven't tried because I cannot afford to buy, is a new router, I am not sure if this is a common problem for routers, to fail to work over time, suppose anything electrical device will.
I can purchase a new router if PN can reinburse me if it makes no difference.
As you can probably tell, I am running out of ideas.
Oldjim
Resting Legend
Fixes: 63
Plusnet will usually loan you a router for testing - worth asking
leewilson78
Ok, I will, Plusnet, can you load me a router for testing?
