Unacceptable connection speeds
- Feedback
- Plusnet Feedback
- Unacceptable connection speeds
Re: Unacceptable connection speeds
06-01-2010 2:45 PM
If you want high speeds for uploading then you should consider the add on for increased upload speeds http://www.plus.net/support/broadband/products/faqs_and_guides/max_premium.shtml
When you say it takes all day can you advise the typical file size and the time it takes. The reason for asking is that it shouldn't be that slow.
It is possible that the company has a dedicated line with much faster upload speeds than ADSL can offer.
06-01-2010 2:48 PM
This afternoon the connection has been on and off, which was always the problem. When I say on and off, the connection seems to be always there, but sometimes a pages takes much longer than it should to load.
I'll assess it though over the next few days.
06-01-2010 2:53 PM
06-01-2010 2:55 PM
06-01-2010 2:58 PM
06-01-2010 3:13 PM
You might like to see if you can get the BT Speed Test to run. What we will be interested in is what it says for your IP Profile. At the moment that will be down around your old speeds; within three days you should see it up at your new speeds and shortly after that you start to see how fast your line can really go.
06-01-2010 3:20 PM
06-01-2010 3:30 PM
06-01-2010 3:34 PM
06-01-2010 3:49 PM
06-01-2010 5:00 PM
07-01-2010 12:39 PM
So I guess the problem could be my computer or wireless connection, can anyone help, I am on a mac with a built in wifi card, it has worked great in the past.
07-01-2010 12:57 PM
Try using http://kismac-ng.org/ ; to see if there are any other wireless networks on the same channel as yourself, if so try switching to a different channel.
Otherwise you could be getting interference from something around you, any new electrical appliances installed lately?
07-01-2010 1:00 PM
07-01-2010 1:21 PM
