Unacceptable connection speeds
- Feedback
- Plusnet Feedback
- Unacceptable connection speeds
Re: Unacceptable connection speeds
04-01-2010 3:56 PM
04-01-2010 4:03 PM
From outside where the wire enters the lounge:
Wire on it way to the telegraph pole:
The wire connecting to the telegraph pole (which is right outside our house):
p.s. it is the worst it has been this afternoon, reset the modem 5 times, just sitting here waiting for pages to load.
04-01-2010 4:04 PM
04-01-2010 4:14 PM
Can you get a photo of the back of the faceplate so that we can see what wires are connected please. It might need an explanation of which is the incoming BT wire and what wires go where.
(You don't need to upload the photos to photobucket - when making your post click the + beside Additional Options and you can directly attach the photo to your post)
04-01-2010 4:27 PM
Right, hopefully this is the faceplate, apologies for the poor image quality.
05-01-2010 9:19 AM
05-01-2010 9:24 AM
05-01-2010 9:29 AM
05-01-2010 10:06 AM
05-01-2010 10:27 AM
05-01-2010 10:48 AM
05-01-2010 10:53 AM
05-01-2010 11:16 AM
If you have a noisy line report that as a voice fault to BT - they must fix that. When you report the fault make no mention of broadband and if they ask you about it tell them that's irrelevant - you just want the noisy line fixed. You may well find that as part of sorting out the line they give you a new master socket for free.
When the noisy line is fixed your broadband will improve all by itself.
05-01-2010 11:22 AM
05-01-2010 11:29 AM
