Slow line speed
rob1user
Re: Slow line speed
ok -
all the wiring done - as per the remove terminals 3 & 4 - so faceplate back on - connceted into master.
Router boot at 11:32 ish :- stats
00:00:45 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7808 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 29.0 dB, Up: 18.5 dB; snr Margin Down: 12.0 dB, Up: 25.0 dB)
rob1user
Re: Slow line speed
Speed test results Friday 18th December - 11:31 ish:-
Today 11:41 1399 kbps (175kB/s) 373 kbps (46.6kB/s) Share
Today 11:41 992 kbps (124kB/s) 296 kbps (37kB/s) Share
Today 11:40 1063 kbps (133kB/s) 257 kbps (32.1kB/s)
better - but will it be fast broadband again in time for xmas Huh
rob1user
Re: Slow line speed
Got a router resync:-
Dec 18 13:08:23
xDSL linestate up (ITU-T G.992.1; downstream: 7104 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 15.0 dB, Up: 29.0 dB)
rob1user
Re: Slow line speed
Just done a plusnet speedtest Friday 18th December @ 19:03 ish
Date Download Speed Upload Speed
Today 19:03 5000 kbps (625kB/s) 379 kbps (47.4kB/s) Share
Today 19:03 3996 kbps (500kB/s) 372 kbps (46.5kB/s) Share
Today 19:02 3608 kbps (451kB/s) 376 kbps (47kB/s) Share
Its starting to look a lot better  Smiley
Anotherone
Champion
Fixes: 21
Re: Slow line speed
Mmm, that sync drop is irritating, Target SNRM has gone to 15dB, so with that sync speed that's a 6M profile.
Can you check your profile at the member centre https://portal.plus.net/my.html?action=data_transfer_speed ?
I'll wait for a reply to the PM before next suggestion.
rob1user
Re: Slow line speed
Anotherone,
my profile:-
Estimated line speed:
5 - Checked on 2009-05-10 14:31:09
Current line speed:
6500
regards
rob
Anotherone
Champion
Fixes: 21
Re: Slow line speed
OK, try for a better sync speed in the morning, post stats, then leave it on 24/7 (whatever the sync). We need to see if the line is stable with no drops.
rob1user
Re: Slow line speed
Switched modem/router on 11:45 ish 19th December
stats :-
00:00:44 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7136 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 29.0 dB, Up: 18.5 dB; snr Margin Down: 15.0 dB, Up: 29.0 dB)
rob1user
Re: Slow line speed
speed test results 11:52ish Sat 19th December:-
Today 11:54 5859 kbps (732kB/s) 380 kbps (47.5kB/s) Share
Today 11:53 5815 kbps (727kB/s) 380 kbps (47.5kB/s) Share
Today 11:53 5864 kbps (733kB/s) 373 kbps (46.6kB/s) Share
Anotherone
Champion
Fixes: 21
Re: Slow line speed
Those speed test results are good for the 6M profile you will have (but as previously mentioned it should be capable of 7M eventually).
Keep monitoring the stats now on a regular basis and post them periodically or if/as soon as you see any change in the downstream sync of 7136.
rob1user
Re: Slow line speed
left the router on since Saturday 19th December 11:30 ish
No sync messgaes in the events log.
speed test at 11:43ish Sunday 20th December :-
Today 11:44 5467 kbps (683kB/s) 374 kbps (46.8kB/s)
Today 11:43 5486 kbps (686kB/s) 344 kbps (43kB/s)
Today 11:42 5489 kbps (686kB/s) 366 kbps (45.8kB/s)
rob1user
Re: Slow line speed
Router has been on since Saturday morning.
It might have re-synced but I haven't got a log entry.
My plusnet profile has changed from 6.5 to:-
Current line speed:
6000
Anotherone
Champion
Fixes: 21
Re: Slow line speed
If it's resynced, the sync speed will be different, posting the stats will confirm.
rob1user
Re: Slow line speed
speed stats Tuesday evening approx 19:50ish
Today 19:51 5375 kbps (672kB/s) 376 kbps (47kB/s) Share
Today 19:50 262 kbps (32.8kB/s) 345 kbps (43.1kB/s) Share
Today 19:48 837 kbps (105kB/s) 377 kbps (47.1kB/s)
rob1user
Re: Slow line speed
Restarted router - Thurs 24/12/09 at 11:55 approx:-
00:00:44 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7200 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 15.0 dB, Up: 25.0 dB)
