Slow line speed
- Feedback
- Plusnet Feedback
- Slow line speed
Re: Slow line speed
16-12-2009 12:11 PM
Can you point me at a step by step guide to the other BT tests.
I am afraid I have had no success. I just get the 404 not found error and its becoming irritating.
Re: Slow line speed
16-12-2009 1:17 PM
There's a guide on our website here: http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
Hope that helps.
Re: Slow line speed
16-12-2009 2:10 PM
Now that link does not help!
Yes - I followed the link, and it explains what to do for the first BT speed test.
So - for the 1st BT speed test I am following all these instructions and its working - as you can see by all the posts of the speed stats on the problem and rant link.
However,
Chris asked me about test 2.
Test 2 doesn't work at all - I reiterate, when I run test 2 - I get a 404 not found error.
The information at the link contains no details about test 2 at all.
So until I have an idiots guide to follow -
regards
rob
Re: Slow line speed
16-12-2009 2:13 PM
Re: Slow line speed
16-12-2009 4:32 PM
I believe Matt has replied to your PM with the information you need to do this.
Re: Slow line speed
16-12-2009 7:23 PM
00:00:43 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7744 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 12.5 dB, Up: 29.0 dB)
Re: Slow line speed
16-12-2009 7:30 PM
Could we have the generic information posted in the thread please, it would no doubt help any others in the same boat. Saw a couple of other threads recently where further testing was required but for some reason it wasn't done.
Hi Rob
the stats in reply #26, are you sure they were the correct extract from the log? It looks as though sync has only been established for 44 secs, remarkably similar to the last entry after a (re)sync.
I see the entry you've just posted is 43 secs. but that is as expected since you've just said you've booted, presumably after just doing the other speedtests. I'll just reply to your PM as well.
Re: Slow line speed
16-12-2009 7:39 PM
Today 19:30 89 kbps (11.1kB/s) 312 kbps (39kB/s) Share
Yesterday 20:52 633 kbps (79.1kB/s) 322 kbps (40.3kB/s) Share
Yesterday 20:52 390 kbps (48.8kB/s) 197 kbps (24.6kB/s) Share
Will try the BT one later if I can actually use this sloooow broadband!!
gone for cold tea!!!!!
Re: Slow line speed
16-12-2009 9:04 PM
Just back from the BT test.
Yes did all 3 tests.
But naffing typical, it doesn't save the tests, so i just have the result from test 3:-
test 3
FAQ
This Last Test comprises of Best Effort Test: -provides background information.
Download Speed
64 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 64 Kbps
Additional Information:
Your DSL Connection Rate :7744 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
I am going to post this in the ticket.
Please don't make me do all the tests again sob sob sob
Re: Slow line speed
16-12-2009 9:13 PM
We've received a notification of an MSO(Major Service Outage) tonight, that they identified on the 8th, which may be causing this problem. It's due to be fixed tomorrow.
Re: Slow line speed
16-12-2009 9:16 PM
xDSL linestate up (ITU-T G.992.1; downstream: 7648 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 12.0 dB, Up: 29.0 dB)
Any clues - is the problem me, BT or the internet Provider?
Re: Slow line speed
16-12-2009 9:39 PM
The Test 3 result of 64 Kbps says it's not PN (you are not even connected to the PN network).
That leaves one possibility! http://usertools.plus.net/status/archive/1260999213.htm may well be the reason for your problems.
Re: Slow line speed
16-12-2009 9:46 PM
Re: Slow line speed
16-12-2009 9:48 PM
nice to know for once its not me causing problems
thanks again to everybody for all their invaluable and kind help.
p.s. Anotherone - yes i am still in the master socket - and getting shouted at 'cos no one can use the telephone 😉
Re: Slow line speed
16-12-2009 10:21 PM
