Slow line speed
Anotherone
Champion
Fixes: 21
Re: Slow line speed
Hi Rob,
Ah, right, thanks for all the info. The Thomson 585v7 does have WPA-PSK security, but I don't know if it's WPA2.
You can configure it here I believe  http://192.168.1.254/cgi/b/intfs/?be=0&l0=3&l1=1 and select WLAN.
Can you try it in morning, I'd recommend connecting mid-late morning when noise levels ought to be low. Use the power down method as previously advised. The errors you posted earlier from the Belkin do seem higher than would be desired.
When you power up the 585v7, can you grab the ADSL line stats as soon as sync is achieved, and post when you can.
In the meantime -
1) You spoke about being plugged into the master, is it an NTE5 Master LineBox (the type with the removable lower front plate) and which logo it has on it.?
2) I gather you have 2 fixed extensions. If your master is an NTE5 can you look at the cable connected to the back of that removable faceplate and describe what you see  Hopefully you will see a Blue-white wire on 2 and a White-blue on 5. There may be orange wires on 3 & 4. Can you describe roughly how the cables go from one socket to another.
mal0z
Re: Slow line speed
Yes 585v7 has WPA-PSK WPA & WPA2
rob1user
Re: Slow line speed
ok - my first set of stats from the thompson tg585 v7 at approx 9:21
00:02:01 (since last boot) LOGIN User Administrator logged in on [HTTP] (from 192.168.1.64)
  00:01:03 (since last boot) PPP link up (Internet) [87.112.20.74]
  00:01:03 (since last boot) FIREWALL event (1 of 6): deleted rules
  00:01:03 (since last boot) GRP Default destination is routed via gateway 87.112.20.74
  00:01:03 (since last boot) PPP CHAP Chap receive success : authentication ok
  00:01:02 (since last boot) PPP CHAP Receive challenge (rhost = PTN-AG1)
  00:01:02 (since last boot) PPP CHAP Receive challenge (rhost = ESR1.Sheffield3)
  00:00:45 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 8128 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 11.5 dB, Up: 29.0 dB)
  00:00:28 (since last boot) DHCS server up
  00:00:27 (since last boot) FIREWALL event (1 of 1): deleted rules
  00:00:28 (since last boot) FIREWALL level changed to Standard.
  00:00:23 (since last boot) WIRELESS automatic channel selection done (channel = 11)
  00:00:16 (since last boot) FIREWALL event (1 of 1): modified rules
  00:00:16 (since last boot) FIREWALL event (1 of 1): created rules
  00:00:04 (since last boot) WIRELESS interface turned on.
  00:00:03 (since last boot) [CWMP: 0:00:02.810] setting cwmp defaults
  00:00:02 (since last boot) KERNEL Cold restart
ok - I have droped the face plate on the master socket:-
connected to the master.
wiring is:-
On - 2 blue
On 3& 4 Orange
On 5 - white and blue
wires to the master appear to be green black and white
regards
rob
rob1user
Re: Slow line speed
ok - router stats from powerdown and power up at 11:52 on Monday 14th December are:-
00:01:16 (since last boot) LOGIN User Administrator logged in on [HTTP] (from 192.168.1.64)
  00:01:03 (since last boot) PPP link up (Internet) [87.112.12.118]
  00:01:04 (since last boot) GRP Default destination is routed via gateway 87.112.12.118
  00:00:44 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 8128 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 10.5 dB, Up: 27.0 dB)
  00:00:27 (since last boot) FIREWALL level changed to Standard.
  00:00:03 (since last boot) [CWMP: 0:00:02.780] setting cwmp defaults
rob1user
Re: Slow line speed
Have done another BT speed test at Monday 14th December 12:10ish details below:
Test1 comprises of Best Effort Test:  -provides background information.
Download  Speed
774 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 774 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
jelv
Fixes: 10
Re: Slow line speed
This is looking increasingly like the same problem as http://community.plus.net/forum/index.php/topic,81831.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rob1user
Re: Slow line speed
just got the router stats :- no reboot now since my lunch time reboot:-
  Dec 14 19:56:02 SNTP Synchronised to server: 212.159.13.50
  Dec 14 18:56:02 SNTP Synchronised to server: 212.159.13.49
  Dec 14 17:56:02 SNTP Synchronised to server: 212.159.13.50
  Dec 14 17:41:25 CONFIGURATION mbus igd sync successfull
  Dec 14 17:41:08 CONFIGURATION mbus atomic sync successful
  Dec 14 16:56:02 SNTP Synchronised to server: 212.159.6.9
  Dec 14 15:56:02 SNTP Synchronised to server: 212.159.13.49
  Dec 14 14:56:01 SNTP Synchronised to server: 212.159.6.9
  Dec 14 13:56:01 SNTP Synchronised to server: 212.159.13.50
  Dec 14 12:56:01 SNTP Synchronised to server: 212.159.6.9
  Dec 14 11:56:01 SNTP Synchronised to server: 212.159.13.49
  Dec 14 11:56:01 SNTP Systemtime update: time setting 00:05:35 > new time setting: 11:56:01
rob1user
Re: Slow line speed
Just run the speed test Moday 14th December 20:52ish
FAQ
Download  Speed
92 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 92 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
When will I get my speed back?
when can I plug my extension back in?
not going to be online much more this evening will pick up to-morrow
thanks.
Anotherone
Champion
Fixes: 21
Re: Slow line speed
He's on Unlimited John, not pro/payg - however the throughput is still rubbish for the current profile.
Rob, the good news is that your BT IP profile is the max you can get. That's the first BT profile I've seen rise as quick as that in a while on these boards!
Can you login to https://portal.plus.net/my.html?action=data_transfer_speed and see if your PN one has come up to match.
All we have to do is sort the wiring issue which is responsible for the slower sync speeds and probably responsible for most of your line drops when connected normally.
A brief explanation - it's called the bell wire issue - the orange wire on 3 specifically - it provides the ring signal on a conventional POTS circuit, but is not required or desired in a broadband situation. It's connected by a capacitor to the line on terminal 2 at the master. This un-balances the pair of wires (at ADSL frequencies) that provide your connection. It also acts as a big aerial picking up interference and this lowers your noise margin which results in slower sync speeds.
The solution is easy - all you need to do is gently remove the orange wires from terminals 3 & 4 at the master and at each extension socket.
The connections are IDC (Insulation Displacement Connector) terminals - just gently pull the wires vertically out of the connector - being careful not to disturb those on 2 & 5. Then just coil them back out of the way where they won't touch any other terminals.
A bit more to follow about that bad throughput, but posting this so you can read it.
jelv
Fixes: 10
Re: Slow line speed
Quote from: Anotherone
From the other topic:
Quote from: jelv
It's beginning to look like this problem affects more than just Pro/PAYG.
Anotherone
Champion
Fixes: 21
Re: Slow line speed
I hadn't updated myself on that one at the time of posting.
Anyway once this line issue is resolved, PN will absolutely no excuse for solving the abysmal throughput problem.
Hi again Rob, once you've dealt with the wiring, you should be able to reconnect at your normal socket. Again, use the powerdown method and do so mid/late morning grabbing the stats after sync. The only modem/router line stats that we really need from now are the entries of this format -
Don't forget to check that your profile at the member centre has updated to match BT's.
rob1user
Re: Slow line speed
OK - Its Tuesday 15th December 09
Just gor router stats at 20:05 (still on master socket - nothing else plugged in)
00:00:44 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 8128 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 28.0 dB, Up: 18.5 dB; snr Margin Down: 10.5 dB, Up: 28.0 dB)
Will now do a speed test
rob1user
Re: Slow line speed
Speed Test (ha ha - misnamed!) from Tuesday 15th December 09
FAQ
Download  Speed
21 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 21 Kbps
rob1user
Re: Slow line speed
BT Speed test at approx 23:36
FAQ
Download  Speed
116 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 116 Kbps
Chris
Legend
Fixes: 169
Re: Slow line speed
Did the BT Speedtester prompt you to run another test which would require you changing the password in your router first? If so the results of that would be very useful.
