Service status RSS feed
jelv
Fixes: 10
Has anyone else had problems with the RSS feeds since usertools was moved?
http://validator.w3.org/feed/check.cgi?url=http%3A%2F%2Fusertools.plus.net%2Fstatus%2Fstatus.xml suggests there is an issue.
Odd thing is I can view the feed in IE.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
42 REPLIES 42
Oldjim
Resting Legend
Fixes: 63
Re: Service status RSS feed
No problem with Firefox and emails into Outlook 2003 using RSS Popper
jelv
Fixes: 10
What IP address do you have for usertools.plus.net? I'm getting an IP that looks to be on Rackspace!
jelv
Fixes: 10
Oldjim
Resting Legend
Fixes: 63
It goes all round the houses so something is badly wrong
Tracing route to usertools.plus.net [37.188.117.224]
over a maximum of 30 hops:
  1    84 ms    99 ms    99 ms  192.168.1.254
  2    33 ms    32 ms    32 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
  3    32 ms    31 ms    31 ms  link-a-central10.ptw-gw01.plus.net [212.159.2.152]
  4    47 ms    31 ms    31 ms  xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
  5    32 ms    32 ms    32 ms  te-4-2.car5.London1.Level3.net [217.163.45.249]
  6    *        *        *    Request timed out.
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    40 ms    32 ms    33 ms  ae-11-vl-3101.edge3.London2.Level3.net [4.69.202.170]
10    33 ms    33 ms    33 ms  195.50.125.70
11    33 ms    33 ms    32 ms  coreb-edge5.lon3.rackspace.net [164.177.137.40]
12    33 ms    33 ms    32 ms  core5-coreb.lon3.rackspace.net [164.177.137.23]
13    33 ms    33 ms    33 ms  aggr333a-1-core5.lon3.rackspace.net [31.222.133.193]
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *
MauriceC
Resting Legend
Fixes: 17
Agreed, that looks odd.  Pathping shows something similar in the middle of the journey.
I'll flag it up, but I'd guess the networks guys won't see it till the morning.
The Service still appears to be working though Embarrassed
Maurice
spraxyt
Resting Legend
Fixes: 75
Quote from: jelv
nslookup gives 37.188.117.224 which is correct and not responding to pings is intentional. It is where you suggested. I wasn't aware there was a problem with the feed, I'll check the UserTools side later.
David
David
ejs
Aspiring Hero
Fixes: 25
There is presumably a white-list of allowed HTTP user agents, which would explain why it works in a web browser but the validators receive "HTTP 403 Forbidden" response codes.
$ wget "http://usertools.plus.net/status/status.xml"
--2014-10-07 20:47:29--  http://usertools.plus.net/status/status.xml
Resolving usertools.plus.net... 37.188.117.224
Connecting to usertools.plus.net|37.188.117.224|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2014-10-07 20:47:29 ERROR 403: Forbidden.
$ wget --user-agent="Mozilla/5.0 (X11; Linux x86_64; rv:32.0) Gecko/20100101 Firefox/32.0" "http://usertools.plus.net/status/status.xml"
--2014-10-07 20:47:54--  http://usertools.plus.net/status/status.xml
HTTP request sent, awaiting response... 200 OK
Length: 24699 (24K) [application/xml]
Saving to: ‘status.xml’
100%[======================================>] 24,699      --.-K/s  in 0.08s
2014-10-07 20:47:54 (284 KB/s) - ‘status.xml’ saved [24699/24699]
spraxyt
Resting Legend
Fixes: 75
The feed file itself looks to be OK, last updated after the SS post at 15:10. The oddity mid way through Oldjim's trace looks to be Level3 going round the houses. The box itself is at hop 14 or 15 on that trace.
David
David
bobpullen
Fixes: 330
I'm inclined to say there's nothing to see here. The box is now hosted on Rackspace servers and I strongly suspect ejs's rationale for the validators is correct. Exactly what problems have you been having jelv?
jelv
Fixes: 10
No posts received by FeedDemon since 1st October.
Attempting to re-add the feed fails (see attached). Previewing says:
FeedDemon was unable to locate a valid feed for this site.
Edit: http://usergroup.plus.net/pugrss.php and http://usergroup.plus.net/pugrss2.php (I'm not actually subscribed to this one) are also failing.
Edit 2: I'm subscribed to 24 feeds in all, only two are failing (the service status and first pug one). The feeds that are working include two others from Plusnet: http://community.plus.net/feed/ and http://feeds.feedburner.com/Servicestatusnet
avatastic
Quote from: Bob
OT: Rackspace is a secure area of Plusnet's network where an IRCd is not permitted?  Shocked
F9 member since 1999
F9 ADSL customer since 2004
F9 FTTP customer since 2024
bobpullen
Fixes: 330
Quote from: avatastic
Who said anything about Plusnet's network? Tongue
Quote from: Linn
The Usertools website is moving to a new network location where IRC access is unfortunately against our security policies.
Quote from: jelv
Feedly here and that's working fine. Let me have a fiddle with FeedDemon and see if I can replicate the problem. The Usergroup and ourselves have been fixing the odd thing here and there over the last week or so, none of it is stuff that I'd expect to break the RSS feed though? Undecided
Edit: Doesn't seem to be user agent related:
bpullen@pvs-csctools:~$ wget --user-agent="FeedDemon/4.5 (http://www.feeddemon.com/>
--11:02:47--  http://usertools.plus.net/status/status.xml
          => `status.xml.3'
Length: 24,184 (24K) [application/xml]
100%[=========================================>] 24,184        --.--K/s
11:02:47 (829.64 KB/s) - `status.xml.3' saved [24184/24184]
Fixes: 1,495
it's like the weird one of service status emails going into spam for me since the move.. which is still happening.
avatastic
To be fair, I'd automatically consider mail from a rackspace IP to be spam too.
Quote from: Bob
Nothing is insecure at present, however we have legitimate concerns about continuing to run an IRC daemon from the location we're moving the Usertools server to.
I forgot to ask at the time for you to elaborate  Grin
