Sam knows testing
NedLudd
Re: Sam knows testing
That's the one I've got Jim!
I've connected it to the one gig port on my Billion to give me a 1gig switch. Still need the slower ports on the Billion though as I've 8 Ethernet connected gubbinses!  Cheesy
Geoff,
York.
ricke17
I got the same model and all hooked up - the only issue I got is that in the instructions is says that the WPS LED flickers for 30-60 secs and goes solid but mine remains flickering.
I have emailed them anyhow to see what they suggest, I have switched it off and on a couple of times but still the same.
Fibre Broadband 80/20, Netgear D7000
drunkenmonkey
Mine is out for delivery, did it fit through letterbox or will I need to go pick it up since I won't be in till this evening?
ricke17
Nah, it won't fit through the letterbox, although I didn't have to sign for it.
drunkenmonkey
Cheers will go down to delivery office tomorrow morning and get it then!
ricke17
Yeh nice one
pjmarsh
Fixes: 24
I've just received a TL-WR741ND and a TL-WDR3600 for two different connects that I signed up for.  I think I've sussed why they are different.  The TL-WR741ND is for the ADSL connection and the TL-WDR3600 if for my Fibre connection.
Phil
VileReynard
Fixes: 20
Does the device act as a proper router or as a router that has been hacked to operate as a switch?
If it's the former, I'll sign-up for the new gadget.
ricke17
I'm not technically minded but it seems to be a switch which has customised software on board to monitor things. Essentially you connect it from the WAN port in the tp link to an Ethernet port in your router. And all wired drives are connected via the tp link.
VileReynard
Fixes: 20
Yes - similar to that's what I've got; which is a router that's had the guts ripped out to turn it into an average switch that can do speed tests.
So if it isn't a router, so why are people quoting all that high-end tech specs about these boxes.
Oldjim
Resting Legend
Fixes: 63
because it is now acting as a high end switch with Gbit ports and two USB ports for example
PeeGee
Quote from: vilefoxdemonofdoom
It is a router, but it has been set up in bridge mode to use custom firmware, effectively disabling the normal routing/firewall functions. The WAN interface still uses DHCP to get an address etc. which is used to run the tests and accept configuration parameters (mine changed settings from 2.5Mb ADSL2 to 76Mb then 38Mb fibre).
At the time of applying, I specified a Gb local network, so got a 3600 on 2.5Mb ADSL2.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Jaggies
Quote from: Oldjim
Yeah, but the USB ports are disabled, according to the blurb, and the wireless aerials are just for monitoring available WiFi. They don't transmit an SSID, anyway.
drunkenmonkey
Got mine this morning all plugged in and just lots of green lights flashing, I take it that's it? Nothing more to it?
ricke17
You'll get an automated email within 48hrs with your login details for the website, although mine came with 6hrs.
