Sam knows testing
rookey
Sam knows testing
Guys
Here an idea us lot who getting poor speed with plus net why not join Sam knows testing and show plus net up
82 REPLIES 82
AndyH
Re: Sam knows testing
Are you trying wired speed tests?
rookey
Yes
ricke17
I have joined Sam Knows and am awaiting receipt of the "white box" - the only thing is I am on a gigabit network and I used to be with BT and was using an older white box which was 100mps.
I have emailed Sam Knows to ask if any of the newer boxes have a gigabit ethernet port and if not then I will just send it back.
Rick.
Fibre Broadband 80/20, Netgear D7000
Mayfly
All Star
I was accepted by Sam Knows but inquired about using power line adaptors with their equipment and they don't recommend it  Cry
Mustrum
Fixes: 81
Although there is nothing wrong with speeds or service, I did have a few problems when I was with BT, also had BT TV at the time, and missed out on a few recordings of the MotoGP, so having something to monitor the line should help.
That said, I too use Gig ports, especially on my NAS, and would not like to go back to 100Mbps, so mine will be going back too if its not Gig!
ricke17
It seems that versions 5.0 and 8.0 of the whitebox have gig ehternet (https://www.samknows.com/broadband/uploads/methodology/SQ303-002-EN-Whitebox-Briefing-Fixed.pdf - scroll down to page 6 of the pdf) - I hope they send me either of these.
Rick.
Necroscope445
Awaiting white box here, though wont do anything for my current situation, got it more to submit data for rural broadband issues.
NedLudd
I've been on SamKnows about three years. My 'black' white-box is a T-Link with gigabyte lan ports!  Smiley
Geoff,
York.
DaveyH
Champion
Fixes: 12
I've been on Samknows for a few years, I was originally supplied the 'whitebox'  with 100Mb LAN (TP-Link WR741) which they then replaced with the black whitebox, a TP-Link WDR3600 which has Gb LAN after asking.
pwatson
My Sam Knows box is just plugged into a switch port on my network rather than as a 'through' device as shown on their installation guide.  As a result I don't care whether it's got a gigabit port or not Smiley
Oldjim
Resting Legend
Fixes: 63
doesn't that potentially muck up the results if the speed test is done while something else is monopolising the connection
pwatson
Potentially yes but, looking at the monthly report, in practice no.  I have had the Sam Knows box lock up on more than one occasion and stop submitting data until a reboot so I'm not happy to pass all my traffic through it...
chrcoluk
the samknows box is designed to delay or cancel a test if the internet is in use.
ricke17
That's good to know - I work from home and access a VPN for the office and download large files too.
It worked ok with my BT line - just hope they send me a GB version.
