Sam knows testing
Den1
Re: Sam knows testing
Guy's,  on the sign up form you are asked what sort of Lan you have via a drop down box at the very bottom of the page, ie 100Mbs or 1Gb, this was one of my concerns as i run a 1Gb lan
Oldjim
Resting Legend
Fixes: 63
I didn't spot that on the signup form and I have just signed up - so what is the default
Den1
The default was 100Mbs  Wink
ricke17
I hope I opted for the gig option - I cannot remember lol
Fibre Broadband 80/20, Netgear D7000
pjmarsh
Fixes: 24
That isn't on the form that I've used.  I've just checked again as I can still access it.  It asks which package you are on, but doesn't say anything about your LAN.
ricke17
I recall my form being like this - if there was a drop down menu I am positive I would have spotted it - we can only wait and see.
Oldjim
Resting Legend
Fixes: 63
I have asked the question of Samknows - will report the result
ricke17
Great - I emailed them yesterday asking a similar question and no reply yet!
Den1
Here it is
Den1
Hope you guys can see that bit small  Roll_eyes
ricke17
ah!  maybe I did select 1gig - I cannot remember
pjmarsh
Fixes: 24
That's definitely a different form than I filled in!
pjmarsh
Fixes: 24
Yep, following the link in Chris's post, takes you to this form, which doesn't have that.  I've had my email saying that I've been accepted on it, and if I know anyone else then get them to use... with a link to that same form.
Oldjim
Resting Legend
Fixes: 63
me too - looks totally different
Den1
The invite came to me direct from plusnet which may explain why the forms are different  ?
