Plusnet Pro Unlimited
- Feedback
- Plusnet Feedback
- Plusnet Pro Unlimited
02-10-2009 6:50 PM
You should make a Pro Unlimited Pack which is basically the Pro option for £19.99 with the unlimited usage.
So what does everyone else think?
Re: Plusnet Pro Unlimited
02-10-2009 6:57 PM
02-10-2009 7:57 PM
B.
11-10-2009 8:32 AM
11-10-2009 10:44 PM
11-10-2009 11:59 PM
18-10-2009 7:58 PM
David
18-10-2009 8:06 PM
maybe a better pay inadvance for extra usage system is needed. ie if you up the usage limit by say 10gb at cheaper price per gb than it is now and agree that is the usage limit on your account and to be able to lower it back down again you need to give a full 30 days notice regardless of when your billing date is so it gives the capicty planers somthing easyer to work with when deciding if they need new segments lighting
also still run the same top up system as there is now at the preminum price with the flexablity to add and remove at short notice
18-10-2009 8:10 PM
18-10-2009 8:14 PM
18-10-2009 8:18 PM
You know, I'm not infrequently reading people offering suggestions for improvements to PN's products that strike me as being quite similar - or sometimes even the same as - was offered with BBYW... it can't help but engender the feeling that a significant step back has been taken with the current products in some respects.
18-10-2009 11:40 PM
Quote from: Be3G ...it can't help but engender the feeling that a significant step back has been taken with the current products in some respects.
Indeed - on the other hand, I would imagine it's much easier for PN to market to "new" customers with the current products, as each falls into a very distinct category. If memory serves (feel free to correct me if I'm wrong), at the time the BBYW products were released, published hard usage caps were a fairly new concept in the market - speaking from experience, it was (and still is!) a tough job to try and explain to someone with no technical background what "usage" actually is, as many people only seem to be interested in the speed of the connection (largely thanks to the media, methinks).
Personally, the Unlimited product suits me right down to the ground - I did consider the Pro product as I do a fair amount of gaming, but the usage limit just wasn't high enough for my needs.
Re:Plusnet Pro Unlimited
20-10-2009 10:49 AM
With regards to the speed issues on the network, we're still looking into these.
