Plusnet - New Network
may123
Re: Plusnet - New Network
Quote from: paulmh5
Quote from: Nibiru
Is there any any reason why that might be the case ?
Yes.  IPs are allocated to your local BT BRAS in small chunks and as BT map you to a single BRAS then you only have that selection to 'pick' from.
Hi Paul , I refer to  your reply to Nibiru question on behalf of my original post, and thank you for it.  Just to add  some details, since I was moved onto this new platform (or network) early this month the majority of my IP allocations have the same three groups of numbers from the left  (e.g 51.9.127.xxx) and only the last  three digits xxx change in the range 000 to 255, but also  for  just a few times I  got  another different group of IP addresses ( e.g 143.159.174.xxx )  so I assume there only just  these two activeIP address groups on my local BT exchange at the moment . would you happen to know how quickly this new network roll out will be so that more groups of IP numbers become available to me. also would you please explain for this new network why sometimes more than others it is harder to change from any givern IP address, when i try to switch the router off/on for an hour or so or do a soft disconnect from the router console page? Regards
Chris
Legend
Fixes: 169
@may123
Bob has replied to your question about this on your other thread already, if you can tell us why it's causing you a problem we can look at whether there is anything we can do to help: http://community.plus.net/forum/index.php/topic,149800.msg1315568.html#msg1315568
summers
Interesting, at 6:14 on 23/3/16 my gateway moved from
lo0-central10.ptw-ag01.plus.net
to
206.core.plus.net
Don't think I've seen a core gateway before, stlighly different sub net, but still on 195.166.0.0/16
Is this a sign that I moved? Not that it made any difference to my connection ....
bobpullen
Fixes: 330
I don't think so. I think it's just missing/incorrect rDNS for the virtual router you're connected to.
summers
Yes did seem a bit strange to be on a core.plus.net - the IP if you need to correct is 195.166.130.206, looks like the whole of 195.166.130.0/24 is in core.plus.net.
rongtw
Fixes: 12
I was on 205.core.plus.net earlier , and was told its still Old network  Lips_are_sealed
Anotherone
Champion
Fixes: 21
With all these things, as Bob has already mentioned, if the rDNS entries are missing/incorrect, then the Gateway will not be identified in the manner that we are used to.
geoffa
Just happened to have a look at the BT availability checker for my line and noted the following comment:-
There is currently a Broadband cease pending or in progress against this line. This cease is due to complete by 13th April 2016. This will not stop you ordering Broadband from a new supplier, but it will delay the provision of the new Broadband service.
Is this to do with moving to the new network? I seem to remember in the early days some people receiving texts saying their lines were being ceased.
grahamt
I'm pretty sure you're correct in that assumption.
My phone number has also got this notice on the BT availability checker, and the date is the same as the one I've been given for my move to the new network.
NorthEasterner
Quote from: geoffa
I recall you saying you're in Newcastle upon Tyne. Same as me.
Will have a look on checker to see if same for me  Undecided
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
bobpullen
Fixes: 330
Quote from: geoffa
Yes it is, it's nothing to worry about.
geoffa
Cheers Bob!
NorthEasterner
Quote from: Bob
Quote from: geoffa
Live in Newcastle as well and don't think I've been moved yet  Kiss
Anyway to find out?
NE
geoffa
It's not scheduled to happen until 13th April!
jelv
Fixes: 10
Quote from: NorthEasterner
Anyway to find out?
If you are not on a fixed IP it is easy - your tracerts will change significantly.
For those on a fixed IP where the tracert doesn't change I'm wondering if the CHAP challenges in the router logs will change - I'm currently seeing this:
Apr 4 07:34:52 PPP CHAP Receive challenge from rhost JUNOS (Internet)
Apr 4 07:34:51 PPP CHAP Receive challenge from rhost bras-red2.sl (Internet)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
