New customer - Still no connection or router
- Feedback
- Plusnet Feedback
- New customer - Still no connection or router
17-02-2014 11:40 AM
After a phone call to the customer services line (where I had to spend 15 minutes on hold building up my mobile phone bill) we got an online question raised against our account and were told that the phone line would be reconnected on the 18th Feb and the broadband would take 5 more days after that date.
So we are without internet and a home phone line while paying for it from the 15th. We've received no router and no contact besides the initial welcome email. I thought Virgin Media were bad but this is already worse. Is this how all new customers are treated? Get the account and then ignore them? Not a good start I'm afraid.
Re: New customer - Still no connection or router
17-02-2014 1:34 PM
It looks like this has happened part due to an inappropriate expectation being set and an issue with the order being picked up a little later than I would have like to have seen.
Regarding the router I've just dispatched that now. With any luck that should reach you tomorrow. Please let me know if it doesn't.
Unfortunately there's nothing we can do to alter the time-scales involved but I have added an update to ticket 81415168 regarding something we can definitely do for you.
27-02-2014 12:06 AM
Is there any way of telling if we have been connected or not, please? It appears that despite being told otherwise, our connection still isn't active either due to the phone line issues or something else.
27-02-2014 9:12 AM
You may need to run through the router set up process in order to establish an Internet Connection. To do this you will need to do the following steps:
1. Connect an Ethernet Cable to the router and plug the other end into the computer/laptop.
2. Open up your Web Browser (Such as Internet Explorer).
3. In the address bar at the top of the page (where it says http) you will need to delete whatever is in there, and replace this with: 192.168.1.254
4. You will be prompted for a username and password. (These should have been supplied when you received the router)
5. You should now be logged into the Technicolor Gateway. Click where it says 'Technicolor Gateway' (Just once).
6. In the middle of your screen you should see where it says 'Pick a Task', directly underneath that, you should see 'Set up my Technicolor Gateway', please click this.
7. Click, 'Next' >> Make sure Plusnet is highlighted and click 'Next' again.
8. Type in your account username followed by @plusdsl.net and also fill in your account password in the password field.
9. Click 'Next' and then click where it says 'Start'.
10. You should see a screen saying 'Configuring your Technicolor Gateway'. After a few minutes this should complete and you then need to click 'Finish'.
You should then be connected to the Internet. Close the Internet Browser down and open up a new one and you should be free to surf the Internet.
If this doesn't do the trick, please let us know.
27-02-2014 8:01 PM
My fiance just spent the last half hour on the phone only to have come to no working solution. A fault with our connection has been raised and this will add at least another 48 hours to our wait to get connected as we've got to hope an engineer gets in touch with an answer. Given our rural location I imagine it'll be another long wait yet.
28-02-2014 9:09 AM
Can you run through it again and double check that you're typing in the correct details please?
28-02-2014 10:01 AM
28-02-2014 11:04 PM
28-02-2014 11:08 PM
01-03-2014 9:16 AM
username@plusdsl.net
where username was the name you use to log in to the portal?
01-03-2014 4:42 PM
01-03-2014 4:46 PM
01-03-2014 10:13 PM
03-03-2014 9:29 AM
How did you get on with the alternative router?
03-03-2014 3:49 PM
- Feedback
- Plusnet Feedback
