Just Got Up And Running After 4 Weeks
- Feedback
- Plusnet Feedback
- Re: Just Got Up And Running After 4 Weeks
13-03-2013 3:35 PM
13-03-2013 4:24 PM
@ purleigh Sorry to hear that, don't worry we hadn't singled you out that looks to have been due to an unexpected problem with was genuinely out of the norm.
Adam
13-03-2013 5:43 PM
No it wasn't, it was actually quite consistent with MANY other tickets that I have raised recently.
I have had all sorts of trouble where ticket answering staff are completely unaware of how legacy products work and telling me the only solution is to change to a current product - they were WRONG !, tickets that have taken up to eight days to even get a first response - let alone be resolved, tickets that are incorrectly actioned - so have to be revisited, and tickets that staff acknowledge as being a problem then repeatedly returning the tickets unsolved back to the 'ticket service pool' for the next operative to kick into the long grass.
Your ticketing system is broken, ticket answering staff are not adequately trained, and problems raised are given inadequate 'quick fix' solutions rather than any effort made to properly resolve why a particular issue arose so that it won't happen to the next customer.
So no I didn't think I was singled out, your ticketing system has always been inadequate !
I am just thankful that there a few very capable staff that frequent this forum that have been able to help with my issues that have been apparently too difficult for the ticket answering staff to resolve.
Unfortunately there are also some staff on here that are of no help at all, for example -
[quote=abbreviated extract from PM to Adam Walker]
Hi Adam,
I'm looking for some help, ....
All I want to do is ....
My account is 'purleigh' ....
I have tried using the official ticketing system three times now, using the link specifically intended for ....
Unfortunately each time the response indicates that the operative either doesn't understand how ....
I hope you can help !
Three days later the reply was -
Quote Hi Purleigh,
Sorry for the late reply to this. I'm receiving a quite high number of PM's at present so it's untenable for me to deal with them all. To be honest anyone in the CSC should be able to perform the account change you've mentioned without issue, so I'm going to advise raising a ticket.
Adam
...so the advice is to raise another ticket in the hope that I stumble upon a fourth member of CSC who might have a different answer ?
17-03-2013 5:03 PM
I disconnected/reconnected the PPPoA session twice yesterday to gateway hop because there was lag while browsing and it helped to be on a different gateway.Also noticed the uptime has reset too....there must have been a resync that I didn't notice.My download speed has reduced slightly as well.
Any ideas why this has happened...my SN Margin was like 5.9/4.6 before this btw.
DSL Connection
Link Information
Uptime: 0 days, 4:47:31
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.044 / 8.099
Data Transferred (Sent/Received) [MB/GB]: 169,35 / 1,99
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 17,8 / 36,5
SN Margin (Up/Down) [dB]: 6,1 / 9,0
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 71.951 / 0
FEC Errors (Up/Down): 12 / 41.357
CRC Errors (Up/Down): 2 / 45
HEC Errors (Up/Down): 1 / 369
17-03-2013 5:29 PM
The 21CN DLM has a reputation for managing connections quite aggressively; leaving it to manage as it sees fit is often the best approach. If it sees stability and lower error rates it might undo some of these changes in a few days.
17-03-2013 5:50 PM
17-03-2013 5:53 PM
Have you been listening to your phone line recently? Don't forget what I said. It is sounding like a bit of a possibility. You might have to be a bit OCD with the checking.
17-03-2013 10:34 PM
It has been raining very heavily for the last few days here in Edinburgh....perhaps that's played a part in it.My line is a new installation with Plusnet.The engineers checked it when it was installed and said it was all green.
The SN Margin is coming back down I noticed:
DSL Connection
Link Information
Uptime: 0 days, 10:34:50
Data Transferred (Sent/Received) [MB/GB]: 173,84 / 1,99
SN Margin (Up/Down) [dB]: 6,0 / 8,1
Error Seconds (Local/Remote): 71.983 / 0
FEC Errors (Up/Down): 22 / 124.006
CRC Errors (Up/Down): 2 / 88
HEC Errors (Up/Down): 1 / 799
18-03-2013 9:11 AM
It's not unknown for cordless phones to introduce some noise and we advise people to get hold or a wired phone to double check.
18-03-2013 10:22 AM
18-03-2013 3:39 PM
http://www.argos.co.uk/static/Product/partNumber/5527258.htm
18-03-2013 3:44 PM
If you bought that and still had issues/noise on the line we'd tell you that you had to get hold of a corded phone to double check!
25-03-2013 10:31 AM
Sadly since my upload was uncapped I've noticed lag when browsing...pages taking longer to load.I've gateway hopped but it hasn't helped.I rarely upload and would like the speed it took back on the download side...thanks.
25-03-2013 10:54 AM
Have you checked your Current Line speed (Login required) recently? You need to check it's consistent with the BT IP Profile.
Have you got that corded phone yet?
25-03-2013 11:11 AM
I just checked my current line speed in my Plusnet account and it's went down from 8.3Mb to 7.1Mb now.
Just took these router stats:
DSL Connection
Link Information
Uptime: 1 day, 19:11:57
Bandwidth (Up/Down) [kbps/kbps]: 1.039 / 8.000
Data Transferred (Sent/Received) [MB/GB]: 850,48 / 1,11
Output Power (Up/Down) [dBm]: 12,6 / 0,0
SN Margin (Up/Down) [dB]: 5,8 / 8,4
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 79.112 / 1
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 28 / 7.997
HEC Errors (Up/Down): 18 / 17.412
I haven't turned the router off or touched anything....it has been heavily raining last weekend.But this happened as soon as the upload uncap went through.I still have to get a corded phone to listen for noise on the line.
