IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- IP addresses not UK - Can customers please report ...
Re: IP addresses not uk
02-09-2016 2:23 PM
209.93.118.... range still getting country message via speed/swift and probably archermedia quids corner cashback sites
14-09-2016 2:26 PM
Not wishing to be repetitive 209.93.118 .... range still getting country block on speed/swift cashback sites
14-09-2016 6:12 PM
16-09-2016 11:26 AM
This is simply a continuation of my post under Tech subjects
UKTV is showing me to be in some other country than the UK so I am unable to watch this program on android.
BBC iplayer, ITVHub, all4 work fine.
This is not a major problem but is being reported as requested.
using android tab
16-09-2016 1:47 PM
209.93.194.,,,, Country issue again now on speed/swift sites
21-09-2016 11:08 PM
Having the same issue with UKTV. Emailed them and they're adamant that it's an issue on Plusnet's side, even though I can watch iPlayer, ITV, all4, etc. UKTV say my IP shows me in Japan, they used geoiptool.com to show me. Every IP lookup site I've used shows it as UK based, or the odd California blip. They don't think they need to update any database on their end.
Have you had any luck since?
21-09-2016 11:12 PM - edited 21-09-2016 11:16 PM
Re: IP addresses not UK - Can customers please report any problems here
22-09-2016 9:18 AM
I posted a few weeks ago about not being able to redeem stuff on the Xbox store. I reset my router for a new IP address and that worked for a while, but now it's happening again and I can't seem to get out of 209.93.x.x
My account, console, store page, credit card etc. are all recognised as UK, it's just my IP address makes them think I'm trying to make transactions from overseas.
So last night I got on their support line and they told me to call my ISP with some reference number and they'd sort me out with a better IP. I never actually said who my ISP is though. Do they really have a case open with Plusnet or was that just a fob off? And would Plusnet support actually be willing or able to change my IP address if I call?
26-09-2016 5:06 PM
02-10-2016 1:33 PM
I have similar issue. My ip is .XXXXX and when I try to access some of the contents of online.novasports.gr I get the message that "Content is not available in my Country". I contacted them and they said that my IP is recognised as an US IP and not as a UK IP. There were sometimes that I had a totally different set of IP and the website worked fine. Is anything that you can do?
02-10-2016 2:06 PM
02-10-2016 6:49 PM
Restarting/reconnecting is a workaround but not a proper solution. ![]()
03-10-2016 7:12 AM
Often even rebooting the router results in same Ip address again, sometimes last number/set of digits change and if very lucky the whole IP address changes.
Can the pool of IP addresses be increased?, before network change didnt have problem highlighted above.
05-10-2016 8:56 AM
Ebay locates 209.93.9.xxx in Venezuela, and 209.93.207.xxx in the US.
Please can you persuade ebay to show these as being in the UK?
07-10-2016 4:30 PM
@ghos7 wrote:
hi i think i might have the same problem. my sister cant join certain bingo sites it gives her this error message restricted we are sorry but our games are restricted to certain licensed territories. my starting ip is 209.93.
What sites?
I've contacted them.
Feel free to try contacting them. They've ignored my attempts ![]()
@Elias1988 wrote:
Having the same issue with UKTV. Emailed them and they're adamant that it's an issue on Plusnet's side...
I've pinged them a message so let's see what they say...
Where does it show this and does it cause any problems? I've dropped them a tweet anyway.
Dropped XBox a tweet too, will hopefully get somewhere.
- Feedback
- Plusnet Feedback
