IP addresses not UK - Can customers please report any problems here
cooldude50
Re: IP addresses not uk
209.93.118.... range still getting country message via speed/swift and probably archermedia quids corner cashback sites
cooldude50
Not wishing to be repetitive 209.93.118 .... range still getting country block on speed/swift cashback sites
http://speedcashback.com/     http://swiftpound.com/
bobpullen
Fixes: 327
I contacted both of them, they didn't get back to me Sad
gleneagles
Aspiring Legend
Fixes: 17
This is simply a continuation of my post under Tech subjects
UKTV is showing me to be in some other country than the UK so I am unable to watch this program on android.
BBC iplayer, ITVHub, all4 work fine.
This is not a major problem but is being reported as requested.
using android tab
We are born into history and history is born into us.
cooldude50
209.93.194.,,,, Country issue again now on speed/swift sites
Elias1988
Having the same issue with UKTV. Emailed them and they're adamant that it's an issue on Plusnet's side, even though I can watch iPlayer, ITV, all4, etc. UKTV say my IP shows me in Japan, they used geoiptool.com to show me. Every IP lookup site I've used shows it as UK based, or the odd California blip. They don't think they need to update any database on their end.
Have you had any luck since?
simrjor
geoiptool.com has me in  United States -  El Segundo : IP Address: 209.93.93.xxx
Still lets me watch?
nbrehon
Re: IP addresses not UK - Can customers please report any problems here
I posted a few weeks ago about not being able to redeem stuff on the Xbox store. I reset my router for a new IP address and that worked for a while, but now it's happening again and I can't seem to get out of 209.93.x.x
My account, console, store page, credit card etc. are all recognised as UK, it's just my IP address makes them think I'm trying to make transactions from overseas.
So last night I got on their support line and they told me to call my ISP with some reference number and they'd sort me out with a better IP. I never actually said who my ISP is though. Do they really have a case open with Plusnet or was that just a fob off? And would Plusnet support actually be willing or able to change my IP address if I call?
ghos7
hi i think i might have the same problem. my sister cant join certain bingo sites it gives her this error message restricted we are sorry but our games are restricted to certain licensed territories. my starting ip is 209.93.
vandervagos
I have similar issue. My ip is .XXXXX and when I try to access some of the contents of online.novasports.gr I get the message that "Content is not available in my Country". I contacted them and they said that my IP is recognised as an US IP and not as a UK IP. There were sometimes that I had a totally different set of IP and the website worked fine. Is anything that you can do?
ghos7
log into router and disconnect internet. wait 30 sec then connect. you should pick up different ip. im thinking of getting static ip because this is alot of hassle but if static ip dont work ive wasted money
vandervagos
Restarting/reconnecting is a workaround but not a proper solution. Sad
cooldude50
Often even rebooting the router results in same Ip address again, sometimes last number/set of digits change and if very lucky the whole IP address changes.
Can the pool of IP addresses be increased?, before network change didnt have problem highlighted above.
jjj
Ebay locates 209.93.9.xxx in Venezuela, and 209.93.207.xxx in the US.
Please can you persuade ebay to show these as being in the UK?
bobpullen
Fixes: 327
What sites?
I've contacted them.
Feel free to try contacting them. They've ignored my attempts Undecided
@Elias1988 wrote:
Having the same issue with UKTV. Emailed them and they're adamant that it's an issue on Plusnet's side...
I've pinged them a message so let's see what they say...
Where does it show this and does it cause any problems? I've dropped them a tweet anyway.
Dropped XBox a tweet too, will hopefully get somewhere.
