IP addresses not UK - Can customers please report any problems here
Steeler57
Re: IP addresses not UK - Can customers please report any problems here
Appreciate the efforts. Laura Ashley's working ok today, but John Lewis now thinks I'm stateside!
ASouthall
Hi @Steeler57
Thanks for letting me know. I'm still waiting out responses from the sites that have affected you. Ive reset your line to assign you a new IP address while we get the issue addressed.
Once more thank you for your patience.
If you have any further issues, please get back in touch and we will be happy to help
nigelpbooth
The internet seems to think I'm in Holland, bbc.co.uk doesn't work, changes to BBC.com. PITA.
I'm sure there are many others also.
Kelly
Fixes: 9
When did you see this?  Are you using a VPN or something like Opera which has a proxy built in?    The Community site has seen your latest post coming from a Dutch IP which isn't being supplied by us.
Kelly Dorset
Ex-Broadband Service Manager
Tangoed66
I'm having the same problem with Next and a few other sites thinking I am in the USA, I also have a problem where the wifi connection drops and my iMac either no longer sees the network or if it can see it then it cannot join it unless I do a restart and then it will join automatically again! It's very frustrating!
  • Your Public IPv4 is: 150.143.xx.xxx (I'm not sure whether it's ok to post in full?!)
  • Your IPv6 is: Not Detected
  • ISP: BT Americas Inc
I'm in Cheshire by the way
RandallFlagg
Fixes: 75
Hi @Tangoed66
Thanks for getting in touch. Don't worry about providing the full IP address - I can pull this from your account.
If you could provide a full list of the sites that are being affected and the error messages that you're experiencing, we'll raise this to our network team for you.
Best wishes
Dave
Tangoed66
Thanks, I haven’t noted down the websites it occurs on but there are a few Next.co.uk is the only one that comes to mind but I will take note when it happens again.
As to the disconnection issue, everything will be working fine then a page will suddenly not load, the WiFi symbol on the device will show not connected to WiFi, on some occasions the SSID and others will be listed but on trying to connect I get the unable to join network message, on other occasions there will be no SSIDs found. Despite using network diagnostics I am unable to reconnect unless I restart the iMac.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
RandallFlagg
Fixes: 75
Hi @Tangoed66
Thanks for coming back to me - the wifi issue sounds like it could be IP related if it is resolved by restarting your IMac. Alternatively, it could be a wifi interference issue, which could be resolved via the troubleshooting here.
Let's get the examples of the sites which are affected by the IP issue and I'll raise this for you to our network team.
Best wishes
Dave
Tangoed66
Here are some of the websites locating me in the USA
Next.co.uk
Beautyexpert.com
HQHair.com
Computershare.com
Tusa.com
Linksys.com
Also on doing a Google search the results are not prioritised for UK results, I usually stick UK on the end of my search to sort this.
Thanks Heather
Fixes: 1,615
Thanks for the websites Heather.
Could you try switching your router off for 65 minutes then back on?
This should force your router to pick up a new IP address which should hopefully resolve the issue.
Tangoed66
Thanks @Gandalf I’ll turn off overnight and report back, fingers crossed 🤞
Tangoed66
Thank you @Gandalf
I have now been issued with a new IP address located in the UK, hopefully this will also solve my connection issues.
Thank you for your help
Heather
onecwaddle
Any help would be appreciated.  I am 82 years old, so you will need to talk to me in basic terms.  I am a plusnet customer.  One of my hobbies is online betting.  I use a few different sites, my favourite being William Hill.  However, when I log into William Hill now I get a message that says "We have detected that you are currently located in the UK.  It quotes my IP address as 146.199.198.0.  I have been on their online chat and they say they can tell I am not in the US but their site thinks I am.  They have told me the only way to resolve it is to contact my Internet Service Provider.
Tags (1)
Tangoed66
Hi onecwaddle
Turning my router off for over 65 minutes worked to change my IP address from a US one to a UK one, give that a try before getting into anything more complicated it may just sort you out Wink
LaurenB
Fixes: 131
Hi @onecwaddle, I am sorry for the issues you are having.
This has now been flagged to the relevant team for you. You can try powercycling the router as @Tangoed66 advised, however, there's a good chance you may just get the same IP assigned again.
 Lauren Barry
