How Long Does It Take !!!!! Ticket 31405747 HELP
- Feedback
- Plusnet Feedback
- Re: How Long Does It Take !!!!! Ticket 31405747 HE...
- « Previous
- Next »
Re: How Long Does It Take !!!!! Ticket No30495258
05-01-2010 11:38 AM
Chris
Thanks for your reply because of what you said in a previous post ( I've just checked your account, but there isn't an open ticket nor has there been one since October? ) i raised another ticket (ID: 31405747) to do things the correct way
Cheers .
Cheers .
Re: How Long Does It Take !!!!! F.A.O Chris
06-01-2010 3:12 PM
Had a response from [mremoved] ref ticket 31405747 who looks as if ran some test the asked me to do the same old plug the router in to the master socket C****, the router has been in the master socket for a week now, what the hell is happening
jim:csa
jim:csa
Re: How Long Does It Take !!!!! Ticket 31405747 HELP
08-01-2010 12:42 PM
Can someone @ plusnet look in to this please
08-01-2010 1:55 PM
I couldn't recall whether the last SNR reset was performed before or after your master socket was replaced, so I've requested another one for you as part of the fault investigation. Can you keep an eye on this for the next few days and reboot the router once a day (preferably mid-morning) so it can sync at it's highest speed?
08-01-2010 2:11 PM
Is the router in the master socket or the test socket inside the master socket? (if you have extensions that can make a big difference)
08-01-2010 2:49 PM
Chris
Thanks for the reply, can't reboot mid day as @ work can do 1st thing in morning or after 6
Jelv
The router is in the test socket behind the faceplate and no extensions connected
Jelv
- « Previous
- Next »
- Feedback
- Plusnet Feedback
