How Long Does It Take !!!!! Ticket 31405747 HELP
- Feedback
- Plusnet Feedback
- How Long Does It Take !!!!! Ticket 31405747 HELP
Re: How Long Does It Take !!!!! Ticket No30495258
29-10-2009 9:55 AM
Have you got more than one handset so you can prove it is not that doing it? (or test your handset at a neighbours, or borrow a known good handset).
If you plug the telephone ONLY in to the test socket is there still a crackle? The easiest way to test is to dial 17070 and take option 2 - quiet line test - you should hear nothing.
29-10-2009 10:06 AM
The phone is a bt dect and is a week old so i don't think it can be the phone but i will try it at the neighbours.i have plugged the telephone in only and it does crackle but i will tyr the number you have gave me when i get in tonight.
Thanks for the advice
29-10-2009 10:06 AM
Try the quiet line test and raise a fault with your voice supplier if you still hear the noises.
30-10-2009 7:38 PM
i have had th router plugged in to the mater socket on the main NTE5 socket for a couple of days and the speed has dropped. i have done the speed test on the PN site details below
Today 19:22 488 kbps (61kB/s) 327 kbps (40.9kB/s) Share
Today 06:28 492 kbps (61.5kB/s) 287 kbps (35.9kB/s) Share
Yesterday 20:27 559 kbps (69.9kB/s) 293 kbps (36.6kB/s) Share
Yesterday 06:32 913 kbps (114kB/s) 314 kbps (39.3kB/s) Share
i have looked at the router info details below (don't know what they mean) does it look good / bad
DSL Connection
Link Information
Uptime: 0 days, 0:09:21
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,144
Output Power (Up/Down) [dBm]: 12.0 / 16.5
Line Attenuation (Up/Down) [dB]: 29.5 / 53.0
SN Margin (Up/Down) [dB]: 19.0 / 15.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 1
thanks for the help your and assistance and advice would be greatly appriciated
Cheers
30-10-2009 7:45 PM
31-10-2009 7:13 AM
thanks for the reply yes i rebooted the router before the check, also i have just done a speed check again and the results are the same !
Re:How Long Does It Take !!!!! Ticket No30495258
02-11-2009 12:14 PM
Did you do the quiet line test as advised? If so, what were the results?
05-11-2009 8:08 PM
sorry not updated for a while, i have had a new master socket fitted and the line is crackle free now but i still have the 15db of noise margin on the line, do i need to inform bt to clear this down ?
I now have 1629kbps of speed now and it's like driving a porsche !!!!!
05-11-2009 10:41 PM
The noise margin should sort itself.
10-12-2009 7:39 PM
even though my speed has increased i am not getting the speeds that feel i should expect, i have done all the things asked and the noise margin has not dropped and the speed is no where near what my neighbours are getting, bt say i should get at least 2.5 - 3.0mb download, your advice & help would be very much apprciated
Cheers
10-12-2009 7:49 PM
11-12-2009 11:52 AM
12-12-2009 8:40 AM
If you could get the SNR to be reset that would be great, please let me know when this will commence so i can reset the router.
Cheers
Paul
14-12-2009 9:55 AM
15-12-2009 1:05 PM
Just as an aside, noticed last night that the green broadband light on the thompson router is not as bright as the other green lights, does this make any difference to the speed/connection
- Feedback
- Plusnet Feedback
