Excellent install - happy customer so far.
- Feedback
- Plusnet Feedback
- Excellent install - happy customer so far.
25-01-2013 2:16 PM
1) The engineer rang me at 10:30 not between 1-6 as offered, to see if he could come early. I said he could
2) The phone line and fibre Installs both went like a dream - the engineer was a pleasant experienced and helpful BT guy who knew what he was doing
3) My speeds have gone up from the poor ones I was getting from SKYto around 60 Mb/s
So far, I'm getting very consistent stats from speed testers, compared to the wild variations a Sky Fibre connection was giving me.
BT Speed tester = 60.65
BBC iPlayer Speed test = 58.550
Re: Excellent install - happy customer so far.
25-01-2013 5:15 PM
Great news, always nice to see a smooth install
If you've got any questions for us please give us a shout.
Chris
26-01-2013 9:14 AM
I had to unplug my router yesterday to move it, and my speeds have dropped from 60 to 51.
Have I caused this, and will I have affected my DLM?
26-01-2013 11:30 AM
26-01-2013 12:42 PM
The BT profile + about 3% is the FTTC sync speed so that will give you an idea whether DLM has kicked you.
26-01-2013 2:53 PM
I am connected with a wire.
The output of that BT test is as follows:
- Download speed achieved during the test was - 50.84 Mbps
- For your connection, the acceptable range of speeds is 16 Mbps-61.07 Mbps .
- IP Profile for your line is - 61.07 Mbps
I was getting around 60 yesterday - but I can't tell from this whether it's DLM or not?
26-01-2013 3:03 PM
- Download speedachieved during the test was - 55.44 Mbps
- For your connection, the acceptable range of speeds is 16 Mbps-56.23 Mbps
- IP Profile for your line is - 56.23 Mbps
My sync. is 58.1 Mbit/s
[Edit - Additional info]
My Plusnet 'Current Line Speed' https://portal.plus.net/my.html?action=data_transfer_speed is 78Mb
MY 'Current Gateway' http://usertools.plus.net/@gateway is pcl-ag04
You should be OK to disconnect and reconnect the router on FTTC without affecting DLM, this only monitors the modem sync.
26-01-2013 3:07 PM
26-01-2013 3:13 PM
Quote from: Oldjim What is the current speed here https://portal.plus.net/my.html?action=data_transfer_speed
It's 78MB, Oldjim.
26-01-2013 3:20 PM
26-01-2013 3:24 PM
(It's only day two, and I'm not UNhappy - but if I was getting 60 obviously I'd like to go back to that if possible.)
jim:quote
26-01-2013 3:28 PM
Quote from: w23
You could try a disconnect / reconnect via the router interface to get on a different gateway, you may be on one that's a little congested.
26-01-2013 4:14 PM
I've put in a ticket, just in case.
28-01-2013 9:56 AM
Your line speed has dropped due to the sync rate dropping, I would firstly suggest disconnecting your connection, if you login to your router and click disconnect and power your router and modem off for a few minutes. Then power the modem on and wait for the DSL light to become stable and then login into your router and click connect.
See if your speed has then improved.
28-01-2013 10:01 AM
- Feedback
- Plusnet Feedback
