new router
Purplecat
new router
hi
not long ago I signed up for another package and if I'd have known you had the hub 2 available I would have asked for one. so how do I go about this?Huh
thanks
5 REPLIES 5
Fixes: 1,664
Re: new router
Hi @Purplecat
We're generally only sending a Hub Two in the following instances:
  • Signing up as a new customer
  • Upgrading your broadband package, for example, standard broadband to fibre, or fibre to fibre extra
  • Discussing with our Customer Options Team on 0800 013 2632 at the time of renewing
Having said that, looking Here I can see you're having some issues with your existing router on both a wired and wireless connection. In addition to the troubleshooting steps suggested, it may be worth posting up the Event Log from within your router's settings at 192.168.1.254 as this may help identify the cause for the problem.
Re: new router
@Gandalf
it has been reported here recently that customers who are renewing their contract with you can order a Hub Two
Is this no longer the case?
Dan
Fixes: 1,664
Re: new router
That's where discussing with Customer Options at the time of renewing comes in. Smiley
Purplecat
Re: new router
Well I'm on fibre extra anyway. does that not mean I should have had a new router sent to me anyway?Huh
Fixes: 1,664
Re: new router
Not necessarily, as we're only sending a Hub Two automatically when signing up as a new customer or upgrading.
I'd recommend having a chat with Customer Options when your contract's up for renewal.
In the meantime, I'm happy to help you with the issues you're currently having as there's nothing at this stage to suggest that the Hub One is materially the cause for the problem.
