WiFi drop outs
- My Router
- Re: 2.4 ghz WiFi gone
WiFi drop outs
on 28-12-2020 2:29 PM - last edited on 28-12-2020 8:06 PM by dvorak
My issue at the moment is that my wifi connection is dropping out several times per day. Everything seems fine on speed check and connecting via a cable. Do you think the reset suggested by Thrall is what I need too? I have very basic understanding so any guidance appreciated.
Moderators Note: Topic title changed after split.
28-12-2020 8:05 PM
Moderators Note
This topic has been split from another post for better visibility.
29-12-2020 4:58 PM
@Niven - what router are you using?
29-12-2020 5:17 PM
@bobpullen I'm on a 582n router.
29-12-2020 5:31 PM
Thanks. I've sent you a more recent model. Be interesting to see if it helps.
29-12-2020 5:44 PM
@bobpullen oh! thanks, wasn't expecting that but much appreciated. Will let you know if it improves once set up. Thanks again 🙂
