WiFi drop outs
Niven
WiFi drop outs
My issue at the moment is that my wifi connection is dropping out several times per day. Everything seems fine on speed check and connecting via a cable. Do you think the reset suggested by Thrall is what I need too? I have very basic understanding so any guidance appreciated.
Moderators Note: Topic title changed after split.
5 REPLIES 5
Fixes: 1,483
Re: 2.4 ghz WiFi gone
Moderators Note
This topic has been split from another post for better visibility.
bobpullen
Fixes: 316
@Niven - what router are you using?
Niven
@bobpullen I'm on a 582n router.
bobpullen
Fixes: 316
Thanks. I've sent you a more recent model. Be interesting to see if it helps.
Niven
@bobpullen oh! thanks, wasn't expecting that but much appreciated. Will let you know if it improves once set up. Thanks again 🙂
