Wall mounted router needed
Member
I really hope Plusnet produce a wall mounted router so I can go over to Fibre - the one they sent cannot replace the one I have at present from them which is wall mounted and all the wires come out from the bottom. I have had to cancel upgrading just because of this which is a shame - rewiring would be a nightmare.
11 REPLIES 11
Fixes: 1,662
Re: Wall mounted router needed
Sorry to hear this.
If you'd like still go ahead with your fibre upgrade you'd be free to purchase your own 3rd party router as long as it's a VDSL modem/router. The settings you'll need to set it up can be found here.
Hope this helps.
Member
Thanks for the advise Gandalf but it's an added expense which at the moment I can do without (big dentist bill!). I will stick with what I have and see what the future holds Smiley
Fixes: 1,662
Ah fair. No problem.
Fingers crossed our next router is wall-mounted!
Fixes: 579
@Member the PlusNet Hub one is basically a rebadged BT Home Hub 5. There are wall mount kits available from ebay for the HH5 so they should fit the Hub one fine https://www.ebay.co.uk/itm/BT-Home-Hub-5-Wall-Bracket-/152400928434
Actually this one https://www.ebay.co.uk/itm/Plusnet-Wall-Bracket-Plusnet-Wall-Mount-W-Fixings/152659822199?_trkparms=... claims to be for the Hub one but I would guess in reality it's the same as the one above
Member
Thanks MisterW - I shall look into it. That's really helpful. I've not been on a community site like this before - look what I've been missing! Like to thank everyone for their help.
Fixes: 579
No problem. If you happen to have your own 3D printerGrin then you could download a design from here https://www.thingiverse.com/thing:1157817
Member
Oh now come on - steady on! Grin
IngeJones
As the devices are usually pretty light, perhaps you could put the new one into a net bag or something and hang it from the existing wall fixing?
Another option @Member is to use something like this as it will allow you to remove it with ease.
Fixes: 1,495
Moderators Note
This topic has been moved from Fibre to My Router
chris1610
After buying a black home hub 5 wall mount from the ebay seller, I thought to ask them if they could do it in white, which they apparently could. They subsequently started advertising for the hub one as well.
https://www.ebay.co.uk/itm/Plusnet-Wall-Bracket-Plusnet-Wall-Mount-W-Fixings/152659822199?hash=item2...
(Sorry, see that is already linked to above. I can confirm it is identical to the home hub 5 one, just white plastic instead of black.)
