Using orbi26 hub for access
- My Router
- Re: Using orbi26 hub for access
yesterday
I’ve bought and orbi26 system, trying to set it to kink direct to the full fibre box and do away with the Plusnet router, gone into the settings tried to setup the pppoe setup, selected yes for intervener connection requires login. Added my Plusnet user name with @plusdsl.net, added password select apply. Plug the internet lead from the full fibre box direct to the orbi26 and nothing just will not access the internet anyone any ideas
yesterday
48 minutes ago
Thanks for the reply but I cannot spot where there VLAN setting is to see what it’s set to, any ideas please? I hate technology… !
20 minutes ago
- Connect the cables. Plug an Ethernet cable from your modem or fibre ONT box into the yellow Internet (WAN) port on the back of the main Orbi router.
- Power cycle. Turn off your modem or ONT box for two minutes, then turn it back on alongside the Orbi router.
- Access the admin page. Connect a device to your Orbi WiFi network and open a web browser. Go to orbilogin.com or 192.168.1.1 and sign in using your admin username (
admin) and password.
- Navigate to Internet Setup. Select the Basic tab at the top, then click Internet from the left-hand menu.
- Enable login. Under the question "Does your Internet connection require a login?", select Yes.
- Enter credentials. Choose PPPoE as the Internet Service Provider type. Enter the exact Login (Username) and Password provided by your ISP.
- Save changes. Click Apply at the top of the page and wait a few minutes for the router to establish the connection.
- Check VLAN requirements. Some full-fibre ISPs require a specific VLAN ID (for example, VLAN 101 or VLAN 201) alongside PPPoE credentials. You can configure this under Advanced > Advanced Setup > VLAN/Bridge Settings.
- Verify credential formatting. ISP usernames often require a specific domain suffix (such as
@plusdsl.netfor Plusnet or@broadband.vodafone.co.ukfor Vodafone). Passwords are case-sensitive.
- Check MTU size. If pages fail to load after connecting, go to Advanced > Setup > WAN Setup and change the MTU Size from 1500 to 1492.
- My Router
