Is the default Plusnet router still the WiFi 5 Plusnet Hub Two?
- My Router
- Is the default Plusnet router still the WiFi 5 Plu...
a week ago
Hi guys
I left Plusnet 3 years ago, and am looking at returning as Plusnet currently has one of the best offers alongside EE, and I think I'd prefer Plusnet generally over EE
However, from what I can see Plusnet is still offering the Plusnet Hub Two, the same as the one I got 5 years ago when I joined previously, with only WiFi 5 rather than WiFi 7 or even WiFi 6 like others are offering?
That kinda defeats the point of a 900Mbps Full Fibre package, when the WiFi can't hit that in the real world
Is there an option I'm missing for a better router, or is that genuinely still the offering? I thought about buying one separately but that easily wipes out the savings over my current provider and adds power consumption and a layer of administrative hassle
Re: Is the default Plusnet router still the WiFi 5 Plusnet Hub Two?
a week ago
Yes, that is still the current PN Hub, and I may be wrong here but even a WIFi 6 or 7 hub/router would find it difficult to achieve 900 over wireless - the Hub2 will give you 900, if wired.
a week ago
As far as I'm aware the Hub2 will max out at about 450 Mbps on WiFi.
PN have always been happy for customers to use their own equipment so you could buy a more capable router to serve your requirements.
a week ago - last edited a week ago
"As far as I'm aware the Hub2 will max out at about 450 Mbps on WiFi."
Higher than that, surely? That's below the typical link speed I get on Wi-Fi 5GHz from the Hub 2 to my PC TP-Link dongle.
Typical in my case meaning anywhere from under 600 Mbps to over 700Mbps. I have even sometimes seen it hit the dongle ceiling of 867Mbps. But of course it is, in practice, going to depend on the local environment.
I am only on a 150Mbps FF contract and I am talking about link speed (not data download) which is the only measurable "speed" that makes any sense here, AFAIAC. Numbers also depend on how accurately these connection speeds are, as logged at the Hub 2.
a week ago
@jab1 I get about 1.2Gbps with my current WiFi 7 router on the far side of my house, and I can hit 1.6Gbps with my MacBook if I'm near the router. The Hub 2 used to get me about 380-430Mbps in this same room as I now get 1.2Gbps
Wired is irrelevant for the purposes of this conversation, I do have wired devices but the devices on my WiFi will not be moving to ethernet. If I'm buying a faster connection I'd like it to be available to all my devices that are capable of utilising it
@bmc I used to push about 480Mbps when right next to the router, sometimes nudging a little higher, but yeah that was about the limit. In the room I care about, more like 400Mbps - a perfectly reasonable speed 5 years ago when I moved to Plusnet, but a bit behind the curve today
I'm not interested in buying my own equipment - by the time I've done that, I may as well just go with another provider for the same price and save myself the cost of the other router. And although Plusnet allow it, they don't *support* it, which is fair enough but a reason I don't want to do it. I did it in the past and it was just a hassle having to switch routers back and forth when troubleshooting
And, honestly, there's just the principle of it - if I'm paying for a 900Mbps service I should get a router that can at least handle speeds in that ballpark in the real world
a week ago
Real world I used to get 450-480Mbps near the router, 400Mbps in the office where I need it
I'm not really interested in getting into the minutia of link speeds, I care about the real world transfer speeds achievable either to/from my NAS, or to/from the internet
All speeds I refer to are Librespeed speed tests within my network (to my NAS on 2.5GbE), and/or speedtest.com/fast.com tests out to the internet - although all three were generally within a margin for error because the limit was the WiFi not my internet.
At the time I didn't mind 450-480Mbps with a 500Mbps connection, 90-95% of the speed I pay for is okay-ish. But in this case I'd be looking at more like 50%, which is more than I'm willing to forfeit when I can just go with another provider and get a router that can handle it (or at least be close)
a week ago
@audigex I assume your current router is ISP-supplied?
If you need 900 and still want to move to PN - a budget ISP, then you will need to either buy your own router, or accept the limitations of the budget router they supply.
Do you actually need 900?
a week ago
I am repeatedly amused that folks will buy his & hers gold plated iPhones, top end laptops, UHD TVs, more CCTVs than the Met Police, but will not make a small investment in a suitable home network for the support of all this kit and for a reliable work from home experience.
a week ago
Without full details of @audigex local devices, it's hard to say, but I do not believe the Broadband product speed is the issue here, but the supplied router only being WiFi 5 which will create a local LAN bottleneck when compared with WiFi 6 or 7.
a week ago
fair enough @Dan_the_Van . I'll leave it to the experts.
a week ago
@PhilipHeyes I think you're misinterpreting my question here
I'm not refusing to invest in a suitable router or access point. If it was worthwhile or necessary, I would do so. But the point is that I don't need to. I can either use PlusNet with a WiFi 5 router, or another provider with a WiFi 7 router, for the same money
The question wasn't "Should I buy a 3rd party router/Access Point?", the question was "I have two similar prices for the same 900Mbps OpenReach-based service from two providers, the other has WiFi 7, is PlusNet still only supplying WiFi 5?"
Sure, I could buy my own router... or I could just go with the other provider, because they're the same base price (actually £1/mo cheaper) and effectively they're quite a lot cheaper due to not having to buy a new router
@Dandan It's a bit of both - it would be a LAN bottleneck, but would also prevent me from making full use of a 900Mbps service
LAN is a whole variety of homelab stuff, none of which REALLY matters in terms of speed... but it's 2026 and I can get a provider who will give me a WiFi 7 router, so I'd struggle to justify PlusNet when they only give WiFi 5
WiFi 6 is 8 years old at this point, I'm genuinely surprised PlusNet haven't upgraded their kit - especially when it's based on BT's 2nd gen hub and BT have a 3rd gen one
So in terms of LAN stuff it's probably more the principle of the thing rather than actual real world differences, and for internet then there would be real world benefits for me in faster downloads
a week ago
@bmc Yes. I assume you were asking in case I could just use that, but unfortunately not
- My Router
