Using orbi26 hub for access
- My Router
- Using orbi26 hub for access
3 hours ago
I’ve bought and orbi26 system, trying to set it to kink direct to the full fibre box and do away with the Plusnet router, gone into the settings tried to setup the pppoe setup, selected yes for intervener connection requires login. Added my Plusnet user name with @plusdsl.net, added password select apply. Plug the internet lead from the full fibre box direct to the orbi26 and nothing just will not access the internet anyone any ideas
1 REPLY 1
Re: Using orbi26 hub for access
53 minutes ago
