Using a very old router
Fixes: 392
Re: Using a very old router
@vertex1 Your results do not make much sense, to be honest. The download/upload speeds suggest - to me - that you are on an 80/20 FTTC connection, but the download suggests there is a fault. If you can get 16.2 on upload, your download should be in the 60/70 range.
Fixes: 118
@vertex1
You can use the following to see what speeds OR expect you to receive.
If you don't understand the results post a screen image of the results after hiding your details.
ExForce9
All Star
Fixes: 11
@jab1 wrote:
... the download suggests there is a fault
... or that the speed test was done over WiFi or via powerline adaptors ?  (which would also explain the 43.6 ms latency)
vertex1
This is what it showed:
Fixes: 118
@vertex1
Thanks for the information.
It shows you should be getting between 80 and 65.2 down and 20 to 17.4 up.
vertex1
Interesting. Thanks. Im happy with the speed TBH, it was more the security that I was concerned with. But, after reading the posts, seems like I should be worries about the reverse!
Fixes: 392
As you are below the hand-back threshold, you have a right to raise a speed issue via https://www.plus.net/help/report-a-problem/ , @vertex1
vertex1
Thanks so much all, very helpful. Smiley
vertex1
Ive just logged into the router. Where can I see the firmware version? Ive tried teh Advanced Settings screens, but cant find it. Thanks
Fixes: 392
@vertex1 On the screen in the image attached.
vertex1
Thanks , but I dont have that screen. I have a Plusnet One hub. Ive looked all over for Technical Log and similar, but cant see it
Fixes: 392
OK. Give me a minute. For the Hub1, it is on the screen attached.
