Using own router - no internet
Zzz1
I was using my own ASUS ZenWifi router with BT and all worked fine over PPPoE.
I’ve added my username and password to switch to plusnet, and although my ASUs router shows as having an Internet connection, I can’t load any sites, even with something like 1.1.1.1 as DNS.
Any suggestions as how to get the last part done?
5 REPLIES 5
pint
Re: Using own router - no internet
markhawkin
Champion
Fixes: 22
BT doesn't need a username and password.
Plusnet does.
Has your service definitely changed to BT and does Plusnet's router work?
The link above is good but one thing to note (and often catches people out), if you have "full fibre" (so an Openreach ONT in your home) use the "What settings should I use for a fibre router that's connected to a BT Openreach modem?" instructions.
There are no VLAN tags needed.
SixCopperKs
@pint wrote:
have you tried the guides here:
Interestingly, that guide page (the full-fibre / Openreach modem part) refers to being able to find connection settings in the PlusNet account pages. But, for some reason, connection settings are no longer in the member centre. (I checked on both a FTTP account and a FTTC account.)
So you’d either be guessing it’s [email protected],  checking the PlusNet hub’s auto-configured address, or phoning up.
Zzz1
I’m assuming it’s [email protected] and the account password, but otherwise no clue if it’s authenticating.
With BT, there was a generic username and password which worked fine.
Zzz1
I didn’t see that, thanks
