Using a Hub2 with T P links Deco M5 and FTTC
hellebore1625
Re: Using a Hub2 with T P links Deco M5 and FTTC
Thanks for your replies. I am part way through setting up the deco again and it has asked for a user name and password that my internet service provider will have given me…. When will this have been given and what is it likely to look like? Eg will it be email + password … or is it the username I am using now etc
outcast
Aspiring Champion
Fixes: 19
Have a look at your connection settings in Plusnet "Member Centre"
hellebore1625
It is asking for my PPPoE account name and Password. I have entered the only name and password I could find in the place you told me to look. Where can I find my PPPoE things?
Fixes: 392
Those details are: your Plusnet username and password, which you use to log into the Members Centre.
outcast
Aspiring Champion
Fixes: 19
From Connection setting FAQs -
Confirm the format of YOUR 'username' or 'login name' by looking at YOUR connection settings
hellebore1625
I have entered the password I used to log into my account and my username with the @plusdsl.net on the end and it is still not working. It is telling me that my PPPoE account is invalid.
outcast
Aspiring Champion
Fixes: 19
Have you confirmed whether you still have broadband from Plusnet ?
So far you've told us, that you had FTTC, with broadband and phone from Plusnet, you then 'upgraded' to SOGEA (AKA 'fibre'), at the time you expected the phone service was due to be disabled, your internet connection got disconnected,  without any alternative explanation of any configuration changes by you which might have stopped the broadband.
So why do you think you still have a working internet service from Plusnet ?
If your broadband service has been discontinued, then seeing the message "PPPoE account is invalid" might be true.
Fixes: 392
@hellebore1625  - to follow on from @outcast 's post above have you contacted Plusnet to see if they still have you down as a customer?
outcast
Aspiring Champion
Fixes: 19
It might be worth logging in to the "Member Centre" then visiting this - https://www.plus.net/member-centre/home
On MY closed Plusnet account it shows this banner -
I can't remember whether that appeared when my broadband service ended, or after my final bills were settled.
RealAleMadrid
Fixes: 68
@hellebore1625  Are you able to login to the member centre with the authentication details you have used in the router, i.e. username without the @plusdsl.net and password?  I have come across cases where the router somehow adds an unexpected  space on the beginning or end of the data fields causing PPPoE connection failure.
outcast
Aspiring Champion
Fixes: 19
@hellebore1625
You could attempt the instructions below, and see whether it gives any clues !
hellebore1625
Thanks I’ll try them in the morning if all else fails.
The information I need to set it up is:-
1. I have fibre ( no full fibre in the area) and am presuming this is part of the bt open reach system as that is the name on the plug on the wall ….
2. It deco is asking for connection type … when I set it up previously it was PPPoE , is this correct?
A further option is VLAN ID
Thanks for all your help!
RealAleMadrid
Fixes: 68
@hellebore1625  You have SOGEA which Plusnet call Partial Fibre, connection type is PPPoE. Disable VLAN ID on the router, that is dealt with by the Hub2.
You haven't answered my question about logging into the member centre, can you access your Plusnet account via a mobile connection?
hellebore1625
Yes I can access it
hellebore1625
I’ve sorted it out now thanks for your patience and kindness everyone!
