Using BT Smart Hub (HH6) with Plusnet
JSM15
I've been using the HH6 with Plusnet without issue since Nov 2022, but this this morning the internet disconnected and I noticed my login details had reverted to the default BT log in. I repopulated my Plusnet credentials and did a couple of restarts, but with no success. I then did a restore using the backup file I'd created shortly after going live with Plusnet but this didn't work either. I then tried a factory reset followed by another restore - still no joy.
Does anyone (i.e. @Baldrick1) know whether BT have suddenly blocked the hubs being used with Plusnet?
2 REPLIES 2
mystreet1
Seasoned Pro
Fixes: 7
Re: Using BT Smart Hub (HH6) with Plusnet
Think that you have to disconnect it from the Internet first, remove the connecting cable from the phone socket/ONT.
Enter your details, save them, switch off, connect cable and switch on.
If not, someone with more knowledge will be along, I'm sure.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
JSM15
Update: Just called Plusnet and apparently there's a major outage in my area. This thread can be deleted.
