Using Technicolor as repeater wirelessly
AT
Re: Using Technicolor as repeater wirelessly
Yes secondary router's DHCP disabled. Have rebooted one of the laptops and check firewall is et to private network. Have also been back on TG admin and  disabled WPS also disable Upnp and set its firewall to off. So trying again shortly.
AT
No, that was a non starter. I am using ethernet and powerline adapters to connect the routers. Other devices on the network are working wirelessly. The androids are fine. Two Windows based laptops are not connecting to the internet. Weird. Still trying but not still smiling.!!!!
npr
Fixes: 9
Is the laptop set to a static IP address, best to let it assign the IP address automatically (dynamic IP).
AT
How do I do that?
AT
OK done it. I have checked and it is set to find IP automatically.  Also found, via Network Connection Properties the 'type' is Access Point, the 'connection' shows IPv4 = Internet and the speed is 65 Mbps. The TCP/IP is auto but DNS server is on fixed. Should I change this?
Maddening. All settings suggest to me internet is strong and accessible but I can't reach any sites. Grrr.
AT
I have to turn the secondary off to be able to connect to primary and read/write on this site!  Why do the Androids work ok?
npr
Fixes: 9
Can you please open a command prompt, type the following and post the result.
ipconfig /all [enter]
https://www.google.co.uk/search?source=hp&ei=ksgmWvCWOJCbkwW3vqpA&q=ipconfig+%2Fall+windows+10&oq=ip...
AT
Under what conditions? Do it while connected to primary or secondary or neither?
npr
Fixes: 9
Mainly interested in the technicolor connection but both would be good.
AT
This is what I get when the TG is off and I am connected wirelessly to Hub1 and all is well (TG connection coming shortly):
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\georgealison>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : georgealison-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Physical Address. . . . . . . . . : 00-26-2D-BE-EF-FA
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 1C-4B-D6-E5-8C-C7
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
Link-local IPv6 Address . . . . . : fe80::5dd3:43e2:230c:908f%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, December 5, 2017 3:31:14 PM
Lease Expires . . . . . . . . . . : Wednesday, December 6, 2017 4:53:30 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 303844310
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-25-56-F4-00-26-2D-BE-EF-FA
DNS Servers . . . . . . . . . . . : 208.67.222.220
208.67.220.220
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:2887:3fbc:a88e:782c(Preferred)
Link-local IPv6 Address . . . . . : fe80::2887:3fbc:a88e:782c%11(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 536870912
NetBIOS over Tcpip. . . . . . . . : Disabled
AT
...and this is what I get when connected to TG (which I had to turn off again in order to access this site):
Lease Obtained. . . . . . . . . . : Tuesday, December 5, 2017 5:05:33 PM
Lease Expires . . . . . . . . . . : Wednesday, December 6, 2017 5:05:50 PM
DNS Servers . . . . . . . . . . . : fe80::9e97:26ff:fe78:c910%16
208.67.222.220
208.67.220.220
Hopefully you can spot something in here that is wrong. We have a second laptop which is behaving exactly the same. That's why I think this is a Windows thing (one is on 10 and one is on 7).
npr
Fixes: 9
AFAIK you can not assign your own DNS server in the PN's Hub One router.
So why are both results showing you using Opendns? Is that assigned in the laptop?
Are you sure the technicolor router is now assigned the IP 192.168.1.1
Also ensure no other device on your network is using that IP.
IF you put that IP (192.168.1.1) in your browser do you get the Technicolor GUI's?
AT
I haven't changed anything in the Hub 1 - only looked at the IP address and security settings - as per instructions. I have accessed the TG using 192.168.1.1. but I had problems. I checked the ethernet LAN2 port details and there was no IP address. I had a message saying  'no valid IP configuration'.  I put 192.168.1.1 in for the LAN2  with a  subnet mask of 255.255.255.0 and the default gateway the same as the IP. then I found I was able to access the router when I put that IP address in the browser.  I only did this on one laptop the other I have not even accessed.
Other IPs are
Laptop 1 = 192.168.1.69
Laptop 2 = 192.168.1.66
Printer = 192.168.1.67
Android 10" - 192.168.1.64
Galaxy S6 = 192.168.1.65
AT
Also, I didn't touch any DNS settings because nNon of the instructions I've seen mentioned DNS. Does 'open' mean there are no digits in boxes? What should I do about that?
AT
I have tried accessing the TG on a different laptop this morning and I get nowhere with 192.168.1.1.  It just says can't be reached.  I have got to the gui using that in the past so don't know what's happened. Should I reset it again?
