How To Assign Multiple Devices To DMZ.
Lawzy180
Hi, i was wondering how i assign multiple devices to DMZ. I get to choose from a drop down menu for one device but i was wondering if i could add more than one device if that is possible.
Could someone help please?
Many Thanks.
Tags (2)
7 REPLIES 7
RPMozley
Seasoned Pro
Fixes: 16
Re: How To Assign Multiple Devices To DMZ.
I'm afraid that would be impossible as it would then cease to be a DMZ. A DMZ is suppose to filter all incoming connections to that device, add another device and where's it going to go now.
Maybe a little explanation as to what you are trying to achieve will help find a solution.
That's RPM to you!!
Lawzy180
Hi, i am getting another problem, don't suppose you could help me please.
When i go on port forwarding and add the 'From, To' port range stuff.  When i press apply after adding all the different ports, i get this error message.
Please check attached pictures.
Thanks.
RPMozley
Seasoned Pro
Fixes: 16
Hmm... Special port number. What ports are you trying to set? Also is the DMZ active while you're trying to set this?
That's RPM to you!!
Lawzy180
i’m getting a nat type issue on 2 xbox’s within my house. the nat type keeps switching between open, moderate and strict, resulting in gameplay issue and really bad lag within games.
could you help me with this issue please?
RPMozley
Seasoned Pro
Fixes: 16
Ah right. You may get better advice if you post in the Gaming section here at the forums but you may have to wait awhile for a reply. I don't think there's anyone else online currently.
In the mean time just get together all the relevant info, like port numbers required, the name of the game(s) may help and also mention the router model (which I assume is the PlusNet hub one).
That's RPM to you!!
Lawzy180
I’ve posted in Other Forums > Gaming
Thanks.
Mav
Fixes: 518
Moderator's note:
Thread locked in favour of the new thread mentioned above.
Forum Moderator and Customer
