Using Hub One with an EERO
Lennox1971
Hi - I wodner if anyone can help.
Just bought an eero to get a better spread of wifi around the house. I have read conflicting advice on using the eero with a hub one. Some of the older posts mention that it cant be done and that you need to buy a modem. Others are saying that you can tun off the 2.4 and 5ghz wifi in the router settings. Im just wondering if plusnet have updated the router firmware?  as these mesh routers are going to be more and more popular as they come down to affordable levels.
Appreciate any up to date thoughts - Regards
Tags (2)
5 REPLIES 5
Fixes: 1,473
Re: Using Hub One with an EERO
The eero is a replacement router with mesh network. To get the most out of it would you need a modem to plug the eero into.
You can switch the wifi off on your hub one and plug the eero into it but you won't get the full benefit of all its features.
Something like the BT Whole Home WiFi would create a mesh network without having to replace the router.
Eero and the like are very geared towards the US market where the providers give you a modem and you plug your own router in.
Lennox1971
Thanks - I have bought the eero now (£70 from amazon) so determined to make it work with plusnet !!
when you say "wont get all the benefits of its features" - can you expand?
Fixes: 1,473
To be honest no as I've never used one, but I understand that there are features such as restricting access etc. that may not fully work.
Also think you would need to swtich off any firewall on the eero and dhcp to access any wired network devices.
Lennox1971
No problem - might trying turning off the wifi on the router and see what happens. Will report back for other future users!
Samleech
Hey! Did you have luck using eero with the plus net hub? Was it as simple as plug and play?
