Using 2.4 for smart lights
tiggyb
I recently got a replacement router but cannot get it to switch to 2.4 in order to connect my bulbs (they won't work with the 5Ghz connection). I've searched for advice but only found advice for older systems. From the Hub I cannot see any way to switch over as it looks like this screenshot (see jpg).
Any ideas - at the moment most of my smart bulbs are flashing continuously trying to connect every time I turn them on.
4 REPLIES 4
Fixes: 118
Re: Using 2.4 for smart lights
@tiggyb
Have you tried Advanced Settings - from memory this is where you can change wireless settings.
Fixes: 388
@tiggyb The easiest way (AFAIK) is to split the 2.4 and 5Ghz frequencies - 'how-to' on the router board - and then manually select the correct frequency on the router.
Fixes: 480
@tiggyb
Splitting the bands is the answer, see  https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
You can then choose which band to use for each device individually by going in to the device wireless network settings, where you will see both SSIDs. The password is the same for both.
adam945
Fixes: 113
Hello @tiggyb
I've just split the SSID's on your router, you'll now be able to manually decide whether you want your devices connected to either 2.4GHz or 5GHz. Let us know if you're still having problems.
 Adam
 Plusnet Help Team - Leeds
