Use of Billion 7800DXL with Plusnet/Sagemcom Hub One for FTTC fibre
- My Router
- Re: Use of Billion 7800DXL with Plusnet/Sagemcom H...
- « Previous
- 1
- 2
- Next »
Re: Use of Billion 7800DXL with Plusnet/Sagemcom Hub One for FTTC fibre
24-08-2021 2:31 PM
I know. That's where we started. I think I posted an earlier message after I discovered that, then started this thread a bit later, but I can't find my original.
The answer to "can you use Hub One with 7800DXL?" is "no".
Hence the move to the Huawei modem, and this thread about exactly how to connect and get working.
Simple answer is use the Huawei as modem, connect it to the Billion by a network port, then set the Billion to use it. More complicated answer is that it needs some configuration setting that I can't yet find.
Message 16 of 17
(329 Views)
24-08-2021 2:54 PM
Message 17 of 17
(323 Views)
- « Previous
- 1
- 2
- Next »
- My Router
