Use my own router
psheraton
Use my own router
Hello
So I have bought a TP Link Archer C9  router which obviously doesn't have a modem for VDSL .
I have an old ECI  B-Focus V-2Fub/r Rev B modem.
1st question can I use the ECi modem with plus net?
2nd question if i can't do the 1st question can I put my PlusNet Router into modem only mode? It's a PlustNet Hub1One, made by Sagemcom
Cheers
21 REPLIES 21
Fixes: 1,484
Re: Use my own router
welcome to the forums Smiley
1) Yes you should be able to use the ECI modem - I had one.
2) No, there isn't a modem only mode.
psheraton
Hi Dvorak
Thanks for quick reply I assume I will have to upgrade the firmware as per: https://wiki.openwrt.org/toh/bt/vg3503j
I am reading somewhere else I might have to solder it ?
Fixes: 1,484
Nope, you won't need to do anything to it - unless you want to install OpenWRT?
psheraton
Ok great I will have a go setting it up tomorrow.  I wonder what its default IP address is as I assume I will at least need to enter my plusnet username and password into the modem?
Fixes: 1,484
you don't enter anything into the modem - the user name / password should be entered in your router.
SpendLessTime
Fixes: 86
@psheraton
the Archer C9 Quickstart PDF is here http://static.tp-link.com/Archer%20C9_V5_Quick%20Installation%20Guide.pdf but the default address is http://192.168.0.1/ if you don't wish to read the small guide Smiley
psheraton
I bought the modem off eBay so hence why I was asking. Smiley
SpendLessTime
Fixes: 86
@psheraton
I know humour is hard on web forums, the smile was just to indicate that I wasn't serious about you having to read a 2 page PDF just for that address.
I think it is nice that every manufacturer tries to change the default router address just to confuse you. I have the C5 and it was setup within minutes once I had found that stupid address.
psheraton
Hi Mate
Thanks for trying to help but you didn't actually help at all. You didn't answer the question I was asking.
If you re-read my post you will see what I was asking.
psheraton
Hi Mate
If I am using my own router and modem how will the username be entered unless someone has entered it?
Mustrum
Fixes: 77
The modem does not need anything doing to it, but as has already been said you will need to set up your router with the username and password.
If you are unable to do that, you could use the Hub 1, but you will need the ip ranges in one of the routers,  or tweak the dhcp, there are guides on how to do it in the router section.
SpendLessTime
Fixes: 86
From the PDF for the C9
Launch a web browser, and enter http://tplinkwifi.net or http://192.168.0.1 in the address bar. Create a login password and then click Let’s Get Started.
The username format is yourusername@plusdsl.net and that username and password is the one you use to log onto the Plusnet portal at https://www.plus.net/index_nlp.html
The router will probably have a Plusnet configuration built-in in the "Let's get Started" wizard so hopefully you just enter username and password.
You can check your Plusnet connection settings from the icon "Connection Details" at https://www.plus.net/my.html?action=myconnection
psheraton
I will try tonight if I get time thanks for all the help so far.
southerner
I guess if I were doing this the easiest way to me would be to connect the ECI modem to the ADSL/VDSL cable then run a LAN cable between the ECI modem and the WAN port of the Archer router then connecting my network devices via LAN cable or Wirelessly to the Archer router as you would normally.
As mentioned above the ECI modem doesn't require any configuration and your PlusNet credentials would be entered into the Archer router somewhere that mentions PPPoE connections.
