Unable to Port Forward using a Ubiquiti Dream Router
bradleyp
As stated I am using a Dream Router, with the plusnet hub two in bridge mode. After putting my PPPoE details in I am up and running fine however I seem completely unable to port forward. I figured it might be something to do with not having a static IP so I have bought one from plusnet but the issue still seems to be ongoing. Have I missed a step somewhere, has anyone faced a similar issue? Thanks
40 REPLIES 40
Fixes: 579
Re: Unable to Port Forward using a Ubiquiti Dream Router
It shouldnt be a problem but just in case...
Login to your Plusnet account and then go to https://www.plus.net/member-centre/broadband/firewall
Check that it shows OFF , it not then set it to OFF. You will have to disconnect & reconnect the PPPoE session fro any change to take effect.
bradleyp
Thanks for the reply, that takes me to a blank page so I can only assume its already disabled?
Fixes: 579
Its not available on more recent accounts , so that's probably why its blank. Worth checking though...
When you try to make the connection , is there anything in the Ubiquiti logs ?
bradleyp
Yeah I have only been with plusnet a couple of weeks so that will be why.
Nothing I can see in the regular logs. It does provide the option to log the port forwarding rule itself, which I have enabled and don't see anything for that either.
Fixes: 579
If the connection attempt is reaching the router, I'd expect either an intrusion log or a confirmation of the forward.
Are you connecting directly using your IP ? are you sure that is the IP you currently have ? either check on the router WAN connection or use something like https://whatismyipaddress.com/
bradleyp
I've tried connecting to the static IP and used online port-checking tools, I've even gone as far as setting up a quick game server and asking friends to connect to that, so far none of which have worked.
Fixes: 147
Online port checking tools only work if the device application is waiting (listening) for inbound connections, can you connect to the device on your local LAN to prove it will accept a connection. telnet is a handy tool for that test.
bradleyp
Yeah its working fine on LAN, can connect with no issues.
Fixes: 147
Looking at this link https://www.wundertech.net/how-to-port-forward-on-unifi-devices/ I see it is possible to set Inbound connections (From) to a Limited network range or Any. Did you set the rule to be Any?
A matter of interest what are you trying to forward, have you thought of testing the port forwarding rule will work on the Hub two?
bradleyp
Right now I'm testing it with a Minecraft server (don't judge lol, just done it a million times so its the easiest way for me), my current rule is indeed set to Any, I've not tested it with my Hub Two but I'm about to head out so I'll test it with that when I'm back home. Thank you and MisterW for your replies so far!
bradleyp
Ok just got back and can confirm that port forwarding just with the plusnet router does seem to be working fine, which I find a little puzzling. Any ideas what the issue could be?
Fixes: 147
To confirm, with the Hub Two in 'bridge mode' the light is a purple pink colour?
If you are happy can you post a picture of the Ubiquiti and Hub Two port forward rule you have created?
bradleyp
Yes it is indeed pink, sorry I've already put it back in bridge mode so I cant right now get a photo of the old port forwarding rule. Though it was very similar to this except on my UDR setup I've set that IP as a fixed IP for my PC.
bradleyp
Got a sneaking feeling I've done something wrong with my initial setup, so just posting this if anything jumps out to anyone.
