Unable to Port Forward using a Ubiquiti Dream Router
bradleyp
Re: Unable to Port Forward using a Ubiquiti Dream Router
I'm not familiar with either wireshark or the tcpdump command, so forgive me if I've used this wrong. I ran tcpdump 192.168.1.100 and port 25565 on my PC whilst running the server and using a website to check if the port is open and it returned 0 packets captured, 1 packet received by filter and 0 packets dropped by kernel. Could that filtered packet be important?
Ok, I'm receiving packets when using the port checking website - and not receiving any when the firewall rule is off and doing the same. I feel like I'm on the right path and that I'm about to learn just how stupid I am!
Fixes: 585
Was that specifically to .100 and 25565 as destination ip and ports ?
https://www.howtouselinux.com/post/tcpdump-filters
Fixes: 585
@bradleyp just looking at this https://www.reddit.com/r/Ubiquiti/comments/g25dp8/easiestworking_way_to_view_udm_firewall_logs/ . Seems the firewall logs MAY not be in the main system log ?
Champnet
Fixes: 21
Knowing nothing about Ubiqiti kit just a observation, probably pointless......
Looks like you used 192.168.1.6 - 192.168.1.253 as the DHCP range but given a server the fixed IP 192.168.1.100
I may be misunderstanding the thread but to me that looks like there could be a IP conflict.
bradleyp
Ok I may have jumped the gun with the tcpdump command, wasn't able to see anything else that looked good after that. I had a look through the logs and it is a little difficult to read through. I created a rule to override the other rules and just allow every connection, and after doing that I've noticed a few connections show up with that test rule attempting to connect to 25565, however the open port check still fails?
bradleyp
@Champnet
My guess is that the DHCP server should recognise that as a fixed IP and not assign another device that same IP, I might be wrong but currently no two devices share the same IP
Champnet
Fixes: 21
Fixed IP addresses should be outside the allocated DHCP range though that doesn’t seem to be causing your problem…
bradleyp
@Champnet Ah okay, thank you I'll bear that in mind in future
bradleyp
Okay, suddenly the online port checker has said it can see the port. I deleted the test rule allowing all traffic and its still saying it can see the port - so for now I guess its working? I wish I could tell you what I did but aside from creating that test rule I haven't changed anything
JohnD76
Did you find out what you did to make this work?
I am having the same issue on my UDM SE. It was working not port forwarding is simply not working.
Port checking websites are showing the port as closed and I am tearing my hair out.
Also with Plusnet with a static IP.
bradleyp
Unfortunately no I can’t say there was any specific thing I did. All I can suggest is to repeat the steps I took above. If you're okay taking the risk of allowing all traffic and checking if the port shows up when you run the port checker.
