TP Link AX3000 not connecting
- My Router
- TP Link AX3000 not connecting
27-12-2023 10:20 PM - edited 27-12-2023 10:24 PM
Hi, I have recently started using Plusnet full fibre 300, but found the WiFi signal around the house is poor on the router 2 provided, so purchased a TP ax3000 router and TP link extender for my office (which is fitted other side of house to router but within range).
My problem is I can’t get the TP link router to connect to the wall mounted open reach modem, the router just shows an orange light for ‘internet’ connected. I have tried some of the suggestions with the TP link settings (PPPoE, username/password etc ) but nothing seems to work……maybe I am missing a step somewhere or trying to connect it with the wrong settings.
Any step by step suggestions how to set this router up would be great.
(I’ve been massively frustrated with this so any help would be great!) …..thanks
Message 1 of 3
(1,626 Views)
2 REPLIES 2
Re: TP Link AX3000 not connecting
17-03-2024 9:57 AM - edited 17-03-2024 9:59 AM
Have a read of this:
https://community.plus.net/t5/My-Router/Tp-link-AX3000/td-p/1948759
Just noticed this is quite old. Hopefully sorted ny now!
Message 2 of 3
(1,406 Views)
17-03-2024 10:12 AM
Yup, it was an incorrect password.
Message 3 of 3
(1,399 Views)
- My Router
