Router and laptop
SteveDee
Router and laptop
Hi there!
My first post in the community, although I have been with Plusnet for many years.
My problem is that I cannot get my laptop to see the router through Wi-Fi. I can get it to work with an ethernet cable, but although I have tried a USB dongle, I cannot get the laptop to recognise the router. I just get a message saying 'you cannot access this network' - yes, I am entering the correct password and rebooting doesn't work!
All other equipment in the house works fine, TV, phones, tablets, consoles. So I am curious as to why my laptop doesn't see it. Any ideas? I actually took the laptop into a repair shop, where they said both the internal Wi-Fi card and the dongle were seeing their WiFi fine.
Any ideas on how I can tweak the router to work with the laptop, without it impacting on other kit in the house?
I appreciate any responses and advice! Thank you in advance
21 REPLIES 21
Fixes: 480
Re: Router and laptop
Moderator's note:
Thread moved from Broadband to My Router
Fixes: 585
@SteveDee which Plusnet router do you have ?
Do you have the make/model of the Wifi card in the laptop ? and the USB one you've tried ?
SteveDee
It is the Hub Two, which I understand is the latest? My laptop is 7/8 years old and I am not sure if that is the issue? Or what I could do to aid connection, as it still otherwise works fine
Fixes: 387
@SteveDee How long have you had the Hub2? is this the first time you have used the laptop for a long time?
SteveDee
Hi John, have had the hub 2 for around a year, but haven't used the laptop for longer than that. I have reset the network and it worked , but next time I switched on it was the same problem and don't want to have to do that every time, of course!
Is there anything I can be talked through in router settings or laptop that might work? As I say, it worked fine at the repair shop and also at daughter's house. Odd..
Fixes: 387
Can you see the Hub2 in the list of available networks?
SteveDee
It is a Foktech usb WiFi dongle
The repair guy checked usb drivers were up to date and I have tried all the USBs to see if it worked
SteveDee
Yes it sees it and a 'hidden network' but the only way it will connect is if I first plug in the ethernet cable and then it will hold the signal once I remove that
Fixes: 585
The Hub two has both 5ghz & 2.4ghz wifi bands but they have the same SSID (wifi network name) and cannot be split.
This confuses some old devices which may be 2.4ghz only, into believing they cannot connect. A trick that sometimes works is to temporarily disable the 5ghz band on the Hub ( Advanced wireless settings) , connecting the said device and then re-enabling the 5ghz band. Bear in mind that any other devices that are currently connected to the 5ghz band will be disconnected and will likely revert to the 2.4ghz band with reduced speed. Once the 5ghz band is re-emabled you probably need to get these devices to connect back to the 5ghz by manually disconnecing and reconnecting.
Fixes: 387
That does not make sense. If you select that network, and enter the Password(key), is that when you get the 'you cannot access this network' message?
Fixes: 387
@MisterW Never thought of that! 😀
SteveDee
Yes. I have gone into the HubTwo manager and it says both 2.4 and 5 GHz are on
SteveDee
I will try that and report back later, thank you!
@MisterW
My thinking is if the laptop is seven years old then I would perhaps recommend try changing the Wireless Mode from 1 to 2 or 3 to see if that helps
@SteveDee To achieve this change
From the Home page navigate Advanced settings >Wireless >Wireless mode:
First try 2 and then 3
HTH
