TP Link AX3000 not connecting
jjones2208
Hi, I have recently started using Plusnet full fibre 300, but found the WiFi signal around the house is poor on the router 2 provided, so purchased a TP ax3000 router and TP link extender for my office (which is fitted other side of house to router but within range).
My problem is I can’t get the TP link router to connect to the wall mounted open reach modem, the router just shows an orange light for ‘internet’ connected. I have tried some of the suggestions with the TP link settings (PPPoE, username/password etc ) but nothing seems to work……maybe I am missing a step somewhere or trying to connect it with the wrong settings.
Any step by step suggestions how to set this router up would be great.
(I’ve been massively frustrated with this so any help would be great!) …..thanks
2 REPLIES 2
markhawkin
Champion
Fixes: 22
Re: TP Link AX3000 not connecting
Have a read of this:
https://community.plus.net/t5/My-Router/Tp-link-AX3000/td-p/1948759
Just noticed this is quite old. Hopefully sorted ny now!
Fixes: 587
Yup, it was an incorrect password.
